JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Mar 09, 2014
Blueboard gone bad - JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
2answers
Cub cadet mower model GT 2544 pto belt broke replaced with cub cadet belt. Facing the mower from the front the belt comes off the left hand pulley when engaging.
be sure the belt guides are in place. if they are not in place or bent this will cause the belt to fall out of the pulley.
03 Cadillac CTS passenger seat won't recline
many possibilities for that, its an 03, the channel could be stuck, the motor could have gone bad, the switch could have gone bad, a fuse or a relay could have gone bad. Your best bet is to look if the channel is clean and nothing is stuck there then look for a faulty fuse, and if that is okay then you can check if the switch is bad, by swapping it out with an aftermarket or a part from the junkyard, next comes the electric motor for the seat.
Why cant I get windows 7 to start up
That's all the info you give us? Why won't it start?
Maybe the computer isn't plugged in. Did you try and push the power button? Could be a virus. Power supply might be bad. Sometimes Windows just gets corrupted and needs to be reloaded. Your hard drive might have gone bad. The RAM might have gone bad. Motherboard may have gone bad. Power button my have broke. Something might have come unplugged inside.
Where is de @ in skech blueboard
Normally @ symbol can be typed by Shift+digit2.
Control panel not working.
Could be a number of problems...first of all, if you have no display, then it may be the low voltage power supply has gone bad....if you do have display, then either vthe keypad has gone bad or the microprocessor inside has gone bad.
1helpful
Hi, i have a packard bell easynote tj68 which has all of a sudden started beeping when it is booting up, and the computer is gone slow and keeps freezing
Beeping means that you have a hardware failure. Since the pc has gone slow then most probably the memory has gone bad and you will have to replace it. To identify which stick has gone bad just remove alternatively one of them - with the bad one the laptop will not start. Junk it and buy a identical replacement.
Toshiba satellite A305-S6872, stopped responding to any keystrokes
Check if the system just froze. If the cursor moves when using a touch pad or a USB mouse then there may be a physical connection to the keyboard that has gone bad. Check also if there are specific keys that may have gone bad it could be bad contacts underneath the keys that may just need cleaning or bad connections underneath. Underneath the keyboard there should be a line that connects the keyboard to the motherboard. It may have come loose or the connections may have gone bad.
My inverter is continously going bad
Continuously going bad meaning what? It has gone bad more than once? How long in between you replacing it has it gone bad?
See, the thing is most inverters that you will buy are used inverters, what we call "pulls" as they have been pulled from other laptops. It could just be some bad luck, but let me know how many have gone bad....
2answers
Electronic frost-free fridge ices up about once every ten days
you have a defrost problem.
3 things.
1 - defrost heater gone bad.
2- bi-metal / thermo-disc gone bad.
3 electronic timer or mechanical timer gone bad.
tnx 4 using fixya,
drcool
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
