Every time i try to put an equation to graph and then press graph, it says "Argument Error", can you please help me?
The function you give as example in the additional information to your duplicate post is too simple to generate an Argument error. Maybe a syntax error but not an argument error.
Check what you enter on the line that defines the function. Do not confuse the minus sign - (for subtraction) and the change sign (negation sign) marked (-).
You can also reset your calculator by pressing the button on the back.
SOURCE: graphing
The first solution will allow you to watch your
calculator graph two equations simultaneously rather than finishing one
before graphing the next; it won't solve the problem of having the
calculator unselect one equation when you select a second. To fix
that problem, try the following:
In order to select additional graphs, the Transformation Graphing App
will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus
Family. Uninstalling the App does not erase it from the calculator, it
disables it from interfering with the normal graphing modes. Below are
the steps to successfully uninstall the App.
The illustration and solution are courtesy of
Jesse Phillips, who cites
this
page from the Texas Instruments
support site
- doug garfinkel, Children's Day School
SOURCE: My calculator will only graph one graph at a time.
This is simple... Back up all RAM, (press second+, then 2, then 1, press enter to back up something if backed up it will have a star by it) Then clear your RAM (pull out your batteries while the calc is still on or press second+, then 7, then 1)
Hope this helps!
SOURCE: How do you set up window range?
or press ZOOM, option 6 (ZStandard). That instantly resets the window range.
SOURCE: trying to draw graph, what does syn error mean? I
Here is a screen capture to help you pinpoint the location of the error.
