Turn calculator ON If you see no icons, press Menu Press 3 (Graph) draw your function. (more on that later). If the first line of the display show Graph Func : Y= you should be able to draw your function. If it says anything else, press F3 TYPE to select the graph type and select functional by pressing F1 key Y=. After the graph type is set to Y=, type the second member of your function y= f(x) on the first line. Make sure the = sign after Y1= remains highlighted after you move cursor. Otherwise select the function by pressing F1:SEL. Press F6 Draw. Be careful with trigonometric functions. If angle unit is radian, set window Zoom to standard. If angle unit is degree, you must open the Window utility and set Xmin=-190, Xmax = 190 to see at least a period.
Sure it does! Did you ask it to graph?Here are some screen captures to help you find your way. To draw functions (regular, parametric, polar, sequences) use the application graph: Highloghted on 1st screen capture. The second screen captures shows you the functions y=f(x). enter a legal expression and press F6 Draw. To set TYPE press the key under TYPE.
To draw conics (circles, parabolas, hyperbolas, and ellipses) use the CONiCS applications. (See 3rd screen ). On 4th capture the equation highlight is one for the parabola. y=x^2
Scroll down or up examining the small graphs. They will show you which equation form to choose. For the circles
It depends on what you mean by "view several graphs at the same time". If the graphs use the same/single screen then all you have to do is enter each equation on Yx= line in [Y=] editor. Make sure that each [=] sign after the Yx is highlighted.
If you want graphs drawn side by side on multiple portions of screen, I am afraid that is not possible. All you can do is split the screen horizontally (Horiz in MODE configuration screen) or G-T (graph and Table MODE configuration screen). The Gt-T feature allow you to draw A graph and ITS table) side by side.
If you just want to draw figures (not graphs) on the calculator you should use the [Draw] command. Press [2nd] [PRGM] (DRAW) Select [4:Vertical] Command echoes on main screen as Vertical Enter the x-value where you want the line drawn (ex: 2) and press ENTER You will get a vertical line at x=2.
Take 51 sheets of "graph-paper" (1+200 minus 60 minus 50 minus 40).
On the first sheet of paper, label the graph-title as 'Z=40'.
Label the X-axis from 60 to 200.
Label the Y-axis from 50 to 200.
Draw a straight line from (X=60 and Y=(200-60-40))
to (Y=50 and X=(200-50-40)).
On the second sheet of paper, label the graph-title as 'Z=41'.
Draw a straight line from (X=60 and Y=(200-60-41))
to (Y=50 and X=(200-50-41)).
On the next sheet of paper, label the graph-title as 'Z=42'.
Draw a straight line from (X=60 and Y=(200-60-42))
to (Y=50 and X=(200-50-42)).
On the second sheet of paper, label the graph-title as 'Z=43'.
Draw a straight line from (X=60 and Y=(200-60-43))
to (Y=50 and X=(200-50-43).
Keep going for all 51 sheets of graph-paper.
Stack the 51 sheets on top of each other,
to visualize the "3-D" solution to the problem.
P.S. Don't tell your school-teacher that I helped you do your "homework".
Hello, Once you enter an equation the corresponding equal sign is
highlighted by default. Before you draw the 2 graphs, move the cursor
to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain
highlighted. If one is not highlighted, move the cursor on it and press
ENTER.
Once all the = signs for all the functions ypu want to draw are highlighted permanently, press the [GRAPH] key. Depending on the functions ane the window dimensions certain graphs may not show up and one can Zoom out or adjust the window.
If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER] Command PlotsOff echoes on main screen. Press [ENTER], screen displays Done.
If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message. You shouild make it a habit to clear the RAM every time you start a new type of problem.
Hello, Turn calculator [ON]. If you do not see the menu icons, press [MENU]. Use the arrow keys to highlight the [GRAPH] icon. An entry screen appears where you enter the functions you want to graph. On the first line you have Y1= . After the equal sign enter 2[x] [X, theta,T] + 1. When finished press [F6: Draw] Your graph appears on the screen. If you see the axes, but no graph, press [Shift][V-Window] and press [F3:Std] then [SHIFT][QUIT] will take you back to the screen where you enter the functions to draw. There press [F6:Draw].
there are nomerous way to make a graph in c++. you just have to now the code for it.. abse on my knowlegde there are on "for loop" statement that can be use in making a graph in c++.
