I hooked up two different standard DVD players (Magnavox and Coby) to the LG tv but CC won't show up. It works on cable and some DVD movies don't include subtitles like CC only. I can't watch the movies like that. How do I hook the dvd player up and make CC working for the DVD movies (some DVDs don't have subtitles included). Please help! Thanks!
SOURCE: hooked up cable box, wii box and dvd player to new
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
SOURCE: I just hooked up a
Hello
Connections with DVD-TV is of main concern. For HDCP connections, very high quality cables [like Monster Cables] should be used. There is special type of cables to connect to HDCP. The length, wire guage, shield of these cables are of special types, and signal loss will be negligable. Connect the TV with DVD with good quality cable packed specially for HDCP. This will solve the problem. OK.
Btw, the model is LG 42CS570 42 inch
