Dear Industrial sewing machine operators,
My friend bought this sewing machine and I can't find a manual or any information on how to thread it properly and make it work. I do not believe it is broken at this point. I think I don't know how to operate it properly.
Can you help?
vgibson @vix.ca
I have the manual in pdf form here
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Seems this industrial machine is branded with several well known makes. I have purchased the machine direct with the manufacturerTamata and the model is a PF8500 which is branded as a Brother SL7553A or Brother DB2-B755 - Also known as Wimsew High Speed Lockstitch Industrial sewing machine.
Re: query by hawthornhedg Please please could I have the pdf? I have had my machine serviced (at great cost) and know that it works OK but find it far too fast for normal sewing jobs and wonder if there is a way of slowing it down by adjusting the pedal. Hello, I know that this thread -and your question- is tad dated, but since nobody answered I decided to post my explanations. Besides, those are rather "universal" issues, so others might benefit from my advices as well. About the manual: The manual, as a pdf file is available, surprise surprise ;-) on... brother-usa.com website: http://www.brother-usa.com/ModelDocuments/Consumer/Instruction%20Manual/IM_DB2_B755_EN_5013.PDF It is NOT the same manual that was available here - it is kinda abbridged, multi-lingual version - but it still contains all the info about various adjustments and user-serviceable parts. Abridging in this case means getting rid of all that superfuous "safety precautions", like "don't drink the lubricating oil", "don't sew through your fingers with dirty needles" - and other such pieces of wisdom. If one cannot live without abovementioned knowledge and sophistication, please do visit this page in few days time - I just exchanged few emails with the user mikerbot, to whom I just sent that "bigger" manual - and he's going to upload it on some filesharing service and post the link to it here.
About the "slowing down the machine" (and "regulating the pedal"):
The "pedal" only operates the clutch - providing you've got a standard, flywheel-and-clutch sewing machine motor on your Brother (or Yuki, or Whatnot Brand), either single- or triple phase (doesn't really matter which).
In this case the clutch (pedal-operated) is not really meant to "regulate" the speed (the "top speed", at least), but to provide soft ("smooth") start for the machine - and TEMPORARY only "speed adjustments". (You can use it for that purpose, for example, when starting or stopping making a seam, or when doing some "small and precise jobs".)
But the clutch is just that - a clutch - a single disc, "dry" friction clutch (seehttp://en.wikipedia.org/wiki/Clutch)
Perhaps (I guess so) by "too fast" you meant that the machine starts too suddenly ("jerks") when clutch pedal is depressed - in that case the problem is not really with a "regulation", but -most likely- with too dry disc friction facing (a.k.a. clutch pads).
Although technically it is a "dry" clutch (i.e., not immersed in oil) it still should be greased with a solid grease "every now and then" (preferably, a graphite grease - although plain, regular industrial grease would also do).
Typically, the disk friction facing is made of cork, and it slowly wears off during normal machine use. (Some manufacturers, like then-East German or Chechoslovak ones used formaldehyde resin pads, which are to be used REALLY dry - no grease at all - and are nearly service-free and could last almost a lifetime - but, AFAIK, MOST manufacturers use cork pads.)
Apart from regulating the free play of the clutch, one also has (which is even more important!) to apply periodically some grease on the cork pads.
To do so one has to take apart the clutch-motor assembly (see your MOTOR owner manual; although it should be pretty simple job - a screwdriver or flat spanner, or a hex key, and three screws plus two able hands).
Once the clutch is dismantled, spread a thin layer of a grease on the cork pads (preferably leave it overnight in warm place to let the grease "soak" into the cork), then wipe off excess of the grease and reassembly back the clutch and the "proper" motor.
How often this procedure should be repeated? As often as needed, depending on the use of the machine - for "normal, small workshop use" one good greasing should last for at least couple of months, maybe up to a year, depending on the "style of the operator" and quality of the grease used (that's why graphite grease is recommended - graphite binds to the metal face of the flywheel and makes the whole things work smoother for longer time).Â
Also, some sewing machine motors have two (or more) points on the clutch lever, where a thin rod (or chain) connecting the lever to the pedal can be attached to - in that case try moving the rod (or chain) to the point closer to the "free" end of the lever.
This will make the clutching action smoother, but it may require additional adjustment of free play of the clutch.
If this solves your problem then you're set. If not, and the real problem is the top speed itself, then the solution is going to be more expensive and/ or more complicated.
If you want to "slow down the machine" altogether, you can either slow down the motor itself, or increase the V-belt transmission ratio (i.e. relation of diameters of V-belt wheels on the motor and the machine).
To slow down the motor, the best (?) and simplest way would be to use some electronic device, like VFD (Variable Frequency Drive,http://en.wikipedia.org/wiki/Variable-fr...
Sorry, no idea how these thingies cost - check the power rating or amperage of your motor, and then find "right" VDF device ("right" means ot the same of greater power/ amperage rating, single- or triple phase, depending on your motor).
To slow down the machine "mechanically" one has to change the relative diameters of the V-belt transmission - either to put smaller V-belt wheel on the motor ("driving wheel"), or a bigger wheel on the machine ("receiving" or "driven wheel").
The first is simpler in theory, but motors typically have already rather small driving wheels - so there isn't much room to adjust the ratio.
Some motors have DOUBLE V-belt wheels (i.e. with two "groves" for belt, with different diameters) on the "power output" shaft - in that case is is a snap: one nas to move V-belt to the smaller wheel (and adjust the tension of the belt, of course).
sorry, something is, uh, broken on FixYa website - I can't add the last part of the solution - pls email me directly if you want to know it
I HAVE A COPY OF THE USER INSTRUCTIONS. I HAVE NOT SCANNED IT YET BUT IF ANYONE WOULD LIKE A COPY BY EMAIL I AM [email protected]
I have the same need for the manual.please email to [email protected]
Thanks a ton! I need to find out what kind of oil it needs!
I found a copy of the pdf for this...
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/Brother/Brother_Industrial/Brother_DB2-B755_instruction_manual.htm
$10 for a pdf!!!
Hi, i also need a manual for this machine if anyone is willing to help... i clicked on the link given by flytyer58 but it isnt working :'(
if anyone would be so kind to help, plz could you email me at [email protected]. Thank you.
I also have the same problem.
Can someone email me the solution to thread my DB2 B775-3 machine or the manuel?
Thanks,
[email protected]
Same problem. Just bought machine and need manual, parts list and supplier of parts. Thanks.
Thanks Seafeather!
I posted this for a friend, so I will ask if they want the .pdf.
Very helpful.
vixmusic01
Thanks Seafeather!
Very helpful.
vixmusic01
plz sen me pdf
I have the same problem. DB 2-B758-3
I can't figure out how to thread the machine.
Can anyone help and email me...manual or directions.
Thank you in advance.
please can someone send me a copy of the manual if they have it?
thanks
sophie.x
I have just bought an second hand Brother Industrial and I can't make it sew, can someone share how to thread it correctly with me?
Also looking for the manual for db2 Brother b755-3. Thanks
I too have just got a Brother DB2 B755-3 industrial machine and would love a manual to show how to adjust it.
Thanks, Annie
I have also just got a Brother DB2 B755-3 industrial machine and would love a manual to show how to adjust it.
Regards
TED
Please please could I have the pdf? I have had my machine serviced (at great cost) and know that it works OK but find it far too fast for normal sewing jobs and wonder if there is a way of slowing it down by adjusting the pedal. I remember seeing someone using the machine to repair harness once but can't imagine how they controlled it.
hi, could i have the pdf manual to please. would be a great help. [email protected] cheers, sam.
Hi Seafeather,
I would really appreciate a copy of the DB2-755-3 manual.
Thank you,
Rena
I really need to get the brother db2-b755-3 manuel [email protected]
Hello Seafever. I would really appreciate a pdf copy of the manual. I've searched everywhere. Mail is: [email protected]. Thank you, thank you!
I also have a Brother DB2-B755-3 and would greatly appreciate a PDF copy of the manual.
if someone coould please email it to me at [email protected]
thanks so much!
I also have the Brother DB2-B755-3 Industrial Sewing Machine, but cannot seem to be able to thread it properly.
I received no instructions at all with the machine,and I was wondering if anyone could please send me a copy of the instruction manual.
Many thanks
hello could some one out there send me a copy of the user manual for a brother DB2-755-3 as i am having trouble with it thank you i am trying to machine with a thicker thread and it wont machine i get two stitches and thread breaks julie
I have just bought a Brother Industrial seing machine DB755-2 but without a manual I don't think I can thread it or use it. Can anyone help please
i have the same problem no user manual can you help mabey a copy of pdf file?
Thanks
[email protected]
Hi, I have also fallen into the same trap - is it possible to forward manual to [email protected]. Many thanks - Graeme
I have a DB2-B755-3 Could you please email the PDF to me also
[email protected]
Regards
Everbrito
Hi , I also require a manual for a DB2 B755 3, if anybody out there could send me a PDF copy it would be very much appreciated.
Thanks
[email protected]
I've also bought a brother DB2-B755-3 and missing a manual book, and i just can't get the machine working.
Hi.
After reading this ace site, you seem to be helping a lot of people out with a copy of the manual/pdf.
if you can i will REALLY APPRECIATE a copy, i have looked all over the internet, for hours.... just can't find it????
If you will be kind enough to send me a copy to me... if i need to pay i can send this to you - no probs - or an exchange???
my email is [email protected]
many thanks
also having problems can you please send pdf file
[email protected]
I also would like to have a pdf of the user guide.
Thanks.
no manual and dont know how to thread it
Anyone have any luck getting that manual?
If so, please please email it to me, I'll find a place to host it online so no one will have to go through this again. Thanks for your time
-Mike
[email protected]
hello could someone kindly email the pdf along to me for this model thanks
[email protected]
Hi there I also have no manual, please could i have a pdf file?
[email protected]
thanks
I also would like to get the user's manual. I have some troubles with adjusting the top thread tension on my brother DB2-B755-100, and when I go back and forth, the bottom thread makes some knots.
I also have the same problem with my DB2-B755-3 I can't seem to thread it correctly the thread keeps breaking. Would you have a copy of the manual that you can send to me by PDF to [email protected]
Thanks
Hi. I am new to this site and have noticed a lot of people are asking for help getting a Manual/Instructions for the Brother DB2 b755-3, i have recently bought a second hand one and am having problems with the bobbin not wanting to thread and have run out of idea's for it and am desperate to get it going as the work is pilling up !!! If payment is required that is not an issue through paypal.
My email adress is [email protected]
Many Thanks
Seafeather,
Please would you email the PDF. I have DB B755-3. How does the wirecoils posision because she was rotated on her axel. Please email to [email protected]
Thank you
hi i also have a brother db2-b755-3 with no instruction manuel if someone could please send me a pdf i would be ever so grateful, [email protected], thanks in advance.
I'm looking for a manual ("user", or "service" manual for BROTHER DB2-B755-100) - anyone got one? Could he/she email it to me, please? (Got a second-hand machine, it appears some rather uniportant parts are missing...)
My email address: [email protected]
Thanks in advance
hi seafather,
I have a DB2-B755, also an industrial machine. Can you please send me the manual?? thanks so much
elize
emai: [email protected]
manuel
