SOURCE: F2 error
"F2-31"
Image density sensor fault
"F2-32"
Drum mark sensor fault
"F2-33"
Grid voltage correction problem
"F2-35"
"F2-37"
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
SOURCE: SHARP AR-287 F2-00 error code
Although this appears to be an ATC (automatic toner control) problem and it may list as such in service manual which gives brief description of error code it is often something else.
There is a sponge roller at bottom of toner that wears down considerably and when the hopper is very low or out of toner the otner light will come on(triangle of dots). The customer puts the new toner in and the sudden surge of a large amount of toner cascading into the hopper causes an excessive amount of toner to go past the sponge roller and directly into the developer unit which is directly under toner hopper.
The ATC sensor is on the bottom of developing unit and "reads" the density of the developer /toner ratio and with a very overtoned situation as the one created above you would get an F2-00 code.
What is normally done is to either dump toner out of hopper and replace sponge roller and seals or replace toner hoppers as a whole which is quicker and costs almost rh same as cahnging the sponge roller and seals is more labor intensive.
Also the developer is now contaminated with an excessive amount of toner and the recommende solutin is to replace the developer and calibrate theu service program.
This is hardley recommended by a service man unfamiliar with this mode let alone the customer. I ahve been in the Bay Ridge area for years and as a matter of fact bought an investment property thru Petses Realty. Frank
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
- Toner supply abnormality caused by
installation of unpacked toner cartridge
