Emachines computer won't send out a signal to the computer screen. It's running Windows 7 on an e300 processor with 2gb of ram. Girlfriend bought it refurbished and it has worked fine for a couple of years. I thought at first the beep might be a warning beep that the fan wasn't working. I opened the case and the fan was working. Not sure what to do? Any help appreciated.
SOURCE: Emachines problem... PSU works but comp doesnt turn on
Hi, I don't want to tell you a color because it could be different than the actual. Look at the front of the computer and trace the wire that goes to the switch and follow it to the mother board. If you have a volt meter you could measure the voltage on the mother board pins. The mother board should also have silk screening that says start or on. On the case there should be a drawing of the mother board you can look there as well. I have another critical question. Do you have a green light on the motherboard? If you do have a green light, you can try wiring the pins together that the switch is wired to. (I do not have a drawing of this mother board so I can't tell you that there are three or two pins) if you cannot start the computer when wiring the pins together than you can try reseting the cmos or replace the onboard battery, emachines have a bad reputation for dieing. If you do not have a green light it maybe gone. The case will accept another ATX motherboard if that is the situation. You can go and buy another motherboard. To save yourself heartache make sure you can reuse your memory and hard drive type IDE (ata) VS Sata. You can go on a real learning experience by not paying close attention to all of your connector types.
SOURCE: Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
SOURCE: Emachines T2385 startup problem
Psu is a Power Supply issue but the black screen with a blinking white line is not.
The blinking white line can mean there is no instructions to tell the Computer to boot up. Which could be possibly the system battery (cmos) or Hard Drive.
I would narrow those 3 things down first.
SOURCE: emachines t2899 will come on and fans run but screen is still blank
Actually, the monitor is fine. The problem is that the computer isn't booting. The power comes on and the fans spin, but the system board isn't starting. Try reseating the memory modules in their sockets and clearing the CMOS memory using the jumper on the system board. If the problem continues, try another power supply. Finally you may need to replace the system board.
