SOURCE: won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
SOURCE: The time remaining on the wash cycle is blinking door is locked
M duet was also haveing problems and when it would stop in a cycle it
would flash a leter and a # F 02 I hit cancel and restarted it the time
was all messed up I looked up the code for F 02 and found this page, I
will post the link below. it was a drainage problem I cleaned out a
trap in the pump really easy to do and it just might fix your problem.
Regardless ever Duet owner needs to know this and matain this trap I
pulled out a bowl full of stuck in it. Good luck!
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
SOURCE: washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
SOURCE: Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front
panel under the washer door. Your filter door will be light brown. If
you find
a hose there it is to drain out excess water (water that could not be
drained
by your pump) After you have drained, unscrew the cap and remove all the
junk
inside. Have a large plastic bag to catch junk and water. Refit
carefully after
cleaning out. If not solved, something shd be blocking your pump, check
this
out. F-21 filter blocked.
How abt a nice rating for the free
help?
SOURCE: Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
