SOURCE: Yamaha snowmobile starting issue
check for power to starter w/ testlight when you press start button.if none check for power at starter side of starter solenoid when pressing start button.if none take large screwdriver and wedge between both solenoid posts creating contact w/ key swich on. motor should crank.if it does -starter is good. chek small wire coming out of solenoid for power w/ test light when pressing start,if none check start button contacts or power coming from key switch or wiring from start button to solenoid. if power is at small wire when pressing button but no crank-solenoid is bad.
SOURCE: 95 Yamaha vmax 600 (new belt is too tight)
sounds like the belt is wrong size. double check this,and if it is correct size make sure the secondary clutch is closing all the way.
SOURCE: 1999 Yamaha 1200 XL won't start only start button lights up
Please repost this in the section for motorcycles.
Sounds like the alternator is faulty!
Testimonial: "This is what im thinking also .. But also thinking maybe a chafed wire or bad ground could be discharging or not charging the battery, should this snowmobile run without a battery , should the stator generate enough energy to run snowmobile , if so how can i trouble shoot the stator , how much voltage should it be putting out on which wires ? Thanks"
