One For All URC-3021 Remote Control Logo
A
Anonymous Posted on Feb 14, 2014
Como programo mi control remoto universal one for all urc 11-7840 en un dvd panasonic
Denia Bustillo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 10, 2017
Denia Bustillo
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
435
Points
Tengo un vcr magnabox y un TV Mitsubishi
Me puedes ayudar ?
3 Related Answers
Anonymous
  • Posted on Nov 25, 2009
SOURCE: Describa su One For All URC-3021 Control remoto de
necesito el codigo para tv magnavox
Anonymous
  • 4 Answers
  • Posted on Mar 31, 2011
SOURCE: como programo mi control URC
i need a code to get my tv and remote fixed
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Jul 19, 2011
SOURCE: Tengo un VCR JVC HR-XVC17
hi,
Try any one of the following code for JVC VCR.
0067, 0041
ok
Como programo mi control remoto JS -6212A
C?mo puedo programar un mando universal JS-6212A para un TV atec panda
11helpful
3answers
Tengo un control remoto universal Quantum fx rem 107 y necesito el codigo para programarlo en un televisor DAEWOO
Tengo un control remoto universal Quantum fx rem 107 y necesito el codigo para programarlo en un televisor magnavox
5helpful
2answers
Como programar un control de dish a una tele panasonic
Depende del modelo del control remoto. Pero en general:
Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
Como programo el control de un dvd recording DMEES-15
Hola,
Quisiera saber si tu control remoto es el original de la Panasonic o es Universal?.
Gracias
17helpful
5answers
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
2helpful
Como programo mi dvd panasonic con el control de dish???
Hola! mi nombre es Kimberly Escobar representante con DISH Network servicio al cliente, Entiendo que necesita ayuda programmando su control remoto a su DVD, seria mi placer proveerle las intrucciones e informacion que le pueden ser utiles para que usted pueda programar el control. Para que el control puede funcionar con su DVD existen ciertos codigos que se pueden integrar al control para que pueda funcionar el DVD. El procedimiento es el proximo: en la parte de arriba del control va a oprimir el boton transparente que diga AUX hasta que los demas botones se prendan en rojo, luego deja de oprimir el boton e ingresa el numero 1 seguido por un codigo para el Panasonic DVD por ejemplo 1639. (639 es el codigo) pero siempre van un numero 1 al principio. luego oprime el signo de numero (#) el boton AUX deve iluminarse 3 veces. Despues de eso puede tratar de usar el control con su DVD. Desafortunadamente no le podemos asugurar que funcione pero si gusta tambien nos pueden llamar directamente para obtener ayuda y mas codigos para el DVD. Gracias espero eto sea de ayuda para usted.
10helpful
Codigo del dvd sungale 2026 para control universal motorola
hola tengo un problema tengo un dvd marca sungale y no tengo control le compre uno universal marca lax-max y quiero saber cual es el codigo para este dvd
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
