Can I work graphing problems using the intercept method with the TI-30XA?
SOURCE: graphing
The first solution will allow you to watch your
calculator graph two equations simultaneously rather than finishing one
before graphing the next; it won't solve the problem of having the
calculator unselect one equation when you select a second. To fix
that problem, try the following:
In order to select additional graphs, the Transformation Graphing App
will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus
Family. Uninstalling the App does not erase it from the calculator, it
disables it from interfering with the normal graphing modes. Below are
the steps to successfully uninstall the App.
The illustration and solution are courtesy of
Jesse Phillips, who cites
this
page from the Texas Instruments
support site
- doug garfinkel, Children's Day School
SOURCE: Graph feature is not working on TI-83
you have one of your stat plots on that is what is messing it up. So either turn off the stat plots. Or just reset your calculator. hit 2nd then the plus (+) key then 7 then 1 then 2. Good luck
SOURCE: TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
SOURCE: How do you set up window range?
or press ZOOM, option 6 (ZStandard). That instantly resets the window range.
SOURCE: MATH Graph Style Icons
go to apps menu, go to transform app. click uninstall and go to y= screnn and should be a slash on the left and you should be able to graph more than one equation.
