Here are the fault codes for Crosley ovens:
Failure
Code
Condition
Check/Repair
F1
Defective touch pad or membrane
Replace touch pad or membrane (usually the touch pad)*
F1
Watchdog on board
Replace touch pad or clock assembly (also called the ERC)
F2
Oven too hot
Replace relay board (if present) or bad oven temperature sensor
F3 or F4
Open or shorted oven temperature sensor
Replace oven temperature sensor
F5
Hardware and watchdog circuits disagree
Replace clock assembly (also called the ERC)
F6
Missing AC signal
Check for proper voltage
F7
Function key shorted or stuck button
Replace touch pad or clock assembly (also called the ERC) or un-stick button
F8
Analog/Digital supervisory
F9
Door latch supervisory
Check door lock circuit or replace clock assembly (also called the ERC)
F0
Function key stuck
These are all of the codes for your oven. Why was this not helpful?
Your questions wasn't how much will it cost to fix it. Your question was how to diagnose based on the codes. In my opinion I answered your question. This hurts my rating.
This did not show the code that was displayed on my oven.
thanks that helped alot, but I need to know how much it will cost to fix it...thanks again
I'm sorry you were very helpful, with the codes....
I'm sorry you were very helpful, with the codes....It did help so
I'm sorry you were very helpful, with the codes....It did help so much.........
My mom had the same problem with her Crosely Range. After using the self-cleaning mode - it will not work. It keeps turning itself off. Her model number is CE38000AAW. Can you please help??
What is F9?
oven won't turn on
