When i lift dc24 the metal handle always comes straight up-like it does not lock into positionposition,when i push it down to sit in the small semi circle recess built for the cuff shape there is no click-i see a release button ,but outside the the metal handle there is no cuff to click into?
SOURCE: no suction on dyson dc24 ball
Well i just fixed my Dyson Ball with the same problem you have. My wife and i found out it was a crumpled receipt in the lower section of the hose at the upright/handheld pivot #3 in diagram and it was catching cat hair and other things. I began by removing the canister and turned on the vacuum to see if the direct access to the fan had suction. Then i moved to #5; i reattached the canister and threw in some cat hair into it from the bottom. i turned on the vaccum to see if it spinned around; it didnt. I then moved to #4, i removed the head and then turned on the vaccum to see if maybe the head had a leak at the top connecter; as i predicted the strength was minimal. I then worked my way to #1 to see if the strength was the same or if there was a difference. no difference for us. Well then it must be #3.. of course the last one i checked. I used a small flashlight and peared in and i didnt see anything... i then used a coathanger very softly as to not puncture the hose. i then noticed some hair being pushed out but the main culprit wasnt showing. my wife gave me needle nose pliers and i pried the hose off of the top connection in #3; so i could get a better look; you may be able to push it off with your hands. and viola! a crumpled reciept for 3 Monster energy drinks.... the same ones....i drink... oops!... hopes this helps. just go through it step by step. youll know its working once stuff begins to spin in the canister. almost regretted throwing that dyson registry junk away.
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
SOURCE: kickstand on dyson dc24 will not stand up
Solution to Dyson Ball wil Not stand up / Kickstand will not go down:
I had this problem on my Ball. The metal guides on the red foot lever had jumped out of their tracks and you have to get them back into the guide tracks on the rear wheel assemblies. I pulled on the affected wheel assembly to get the metal post on the red kickstand to reset it where it should be.
SOURCE: how do I get a manual for a DC24 Dyson Ball
Hello There,
Here's a link for your Dyson DC24 Owners Manual (Instruction Booklet) that you requested on our website. Feel free to download the manual and save it on your computer for later use. If you have a problem, or need some help with something on your vacuum, please by all means just add a comment on this page, and I'll be more then happy to walk you through any problem that you may have.
If you found this helpful, please be sure to rate the repair helpful by clicking the thumbs up icons in the top of the page. This is what encourages repair professionals to continue posting free repair advice.
Here's the link:
Dyson DC24 Ball Owners Manual
Thank you,
Chris J.
GoVacuum.com
Testimonial: "Thank you so much.....My son had the vacuum but is now unable to use it & I have it, but had no instructions..Again THANK YOU...Barbara R. Harper "
SOURCE: I have the Dyson Ball DC24. I can't get the roller
Hi its Darran at Dyson.
The brush bar re-set switch would normally resolve this, however as you have tried that, please get in touch with our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US) so that we can help resolve this issue for you.
Kind regards
Darran
Dyson Customer Service
