Per last, Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Bizhub C450
You need to place service call for the transfer belt.
As for Sally's question, select the "seperate Scan" button to combine multiple documents as one file. This will work with or without the auto document feeder.
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
SOURCE: konica minolta bizhub pro c6500 error c2452
Toner low density abnormality
When the developing motor/M (M21) is ON, the maximum detection value of TCR sensor/ M (TCRS/M) is the specified value and the difference
between the maximum detection value and the minimum detection value is over the specified value.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
SOURCE: KONICA Minolta c450 in Windows Vista
go to the printers and faxes page and in the driver properties click on printing preferences click on authentcation/account track and you should be able to enter you name and password from there unless you may have to be logged on as the administrator on your computer to make these changes
