DURAGADGET USB Socket Compact Travel Charger Adapter For Acer Liquid Z2, Acer Liquid E1 & Acer Stream Logo
A
Anonymous Posted on Feb 05, 2014
How to connect zing ear tp-05 touch lamp switch
Mike J.
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 56 Answers
  • Posted on Feb 16, 2019
Mike J.
Expert
Level 2:
New Friend:
Greenhorn:
Answers
56
Questions
0
Helped
152872
Points
206
I need a zing ear part ZE-301D+ZE-109M for a HUNTER CEILING FAN WITH LIGHT #28698
Hunter fan usually requires 3 speed pull chain switch which can be found here:
https://www.ceilingfanswitch.com/product/zing-ear-ze-268s6/
and on/off pull chain light switch, which can be found here:
https://www.ceilingfanswitch.com/product/zing-ear-ze-109/
Zing Ear ZE-301D with ZE-109M is available on this link:
https://www.ceilingfanswitch.com/product/zing-ear-ze-301d-lampholder/
2answers
2answers
I have a hunter fan and my contractor switched the load and green wire in the new zing ear switch. I just need to switch the 2 wires and I can't get the switch open. can anyone help?
I found out that mostly they are connected with fastons. You can get them at hardware or auto parts stores.
From what I've heard Zing Ear switches are a bear when it comes to taking apart or taking off wires.
Good luck.
I hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 03, 2011 • Vacuums
2answers
Need replacement switch for zing ear ze-256 switch. Used in a lamp, has off, lo and high positions
I have the same issue. I bought a ZING EAR dimmer but it won't fit in the space allowed by the pole the lamp is made from.
The switch is simple, the positions are: Off/On/Half.
The switch uses a diode to provide half voltage to the lamp. I have two solutions and I'm not sure which I'll use yet. First, I can use the dimmer but I'll have to get a 500K pot with a switch to fit in the hole. I'll attach wires to connect to the PCB of the dimmer. In essence, I'll remote mount the 500K pot.
The second solution is to get a rotary switch like this:
http://cgi.ebay.com/Lamp-parts-3-way-2-circuit-rotary-switch-5-8-TR-302-/380282854100?pt=LH_DefaultDomain_0&hash=item588a9fdad4
and use the diode salvaged from the original lamp switch. In my switch the diode is still good.
I know this sounds awfully complicated, but it's really not.
Randy.
Email me and I can give better details if you like.
[email protected]
Mar 05, 2011 • Vacuums
Hi. My name is Nivardo, I’m from México and
In the base of the lamp, cut the 2 wires coming in from the wall.
On one wire from the wall, connect it to the same wire going to the lamp (white wire, if you can tell which is which), AND the white wire from the Zing Ear (3 wires connected together).
For the other wire from the wall, connect it to the BLACK wire from the Zing Ear.
For the remaining wire to the lamp, connect it to the RED wire from the Zing Ear.
You also need to fasten the "TOUCH" wire from the zing ear to the frame of the lamp -- the metal part where you would touch the lamp.
That should do it.
2answers
Zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
10helpful
2answers
Ceiling Fan Light Chain Broken; Zing Ear
It's actually a very easy repair. Those pull chain switches are very generic and can be found at home depot or any hardware store for about $3. As far as changing the switch there are only 2 wires to connect and there is no incorrect combination to reconnect them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Top DURAGADGET Luggage & Travel Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a DURAGADGET Luggage and Travel Expert? Answer questions, earn points and help others
