Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
A
Anonymous Posted on Feb 05, 2014
Buttons dont work
How able f1, f2,f3 ,f4,and f5 on ti-84 plus silver Edition alpha no work to shows menu
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Feb 11, 2016
k24674
Level 3:
Answers
8093
Questions
0
Helped
4674981
Points
21596
You must have one of the newer OS versions (MP 2.53 and higher). You don't have anything under F5.
5 Related Answers
John Detringo
  • Posted on Dec 09, 2008
SOURCE: ti 84 plus silver edition language change
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English.
Hope this works for you.
Anonymous
  • Posted on Jun 07, 2009
SOURCE: antilog for ti-84 plus silver edition calculator
"2nd" + "log"
Anonymous
  • 14 Answers
  • Posted on Feb 03, 2010
SOURCE: My TI-84 Plus Silver Edition stopped working
That actually is a result of water damage. You probably need to replace it, or see about getting it taken apart and dried if the water damage was recent. DO NOT take it apart yourself. Go somewhere and ask if that is possible.
k24674
  • 8093 Answers
  • Posted on Feb 21, 2010
SOURCE: I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Anonymous
  • Posted on May 17, 2010
SOURCE: TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
Mixed numbers on to-84 silver plus
If the calculator has the latest OS version, additional menu items are available by pressing the ALPHA key, followed by a function key F1, F2, F3 or F4. One of these choices allows user to select improper fraction display or mixed number display of results.
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
Alpha key not recognized when pushed
When the ALPHA key is pushed the cursor shows an A. Press one of the keys that has the same color as the ALPHA key (A,B,C,...X,Y,Z).
If you have the MathPrint OS, the ALPHA F1/F2/F3/F4 sequence activates shortcuts to newe features (fractions, logab, sums etc..)
6helpful
2answers
I can't see the shortcut menus. When I press ALPHA F1, I get the Y= menu. The ALPHA key is not broken, because ALPHA MATH produces an A as it is supposed to. I've hit 2ND-QUIT and CLEAR several...
I just had this problem: shortcut menus used to work, but stopped, with TI Version 2.55 MP. I discovered that running the preloaded app PlySmlt2 (others work, too) and quitting it fixed the problem, but that later running a non-TI app caused the problem again. So the non-TI app may be misbehaving, as suggested in this TI knowledge base article.
9helpful
2answers
How do you convert from decimal to fraction or fraction to decimal
Use the >Frac and >Dec commands in the MATH menu. Press the MATH button to bring up the menu.
2answers
How do i use the "shades" or "Po-I-Trace" menus on the TI-84?
Press APPS. Scroll up or down to reach Inequalz and press ENTER. The inequalz application will know control function graphing. Open the Y= editor to enter at least two inequalities . Use the tabs at the bottom to type in the relational operators. You will have to press [ALPHA] followed by [F1], or [F2], etc
Press the GRAPH function key (F5) to draw the graphs. You get the two regions superposed (original shading).
Press [ALPHA][F1 or F2] to activate the [SHADES] tab. This open up the following screen.
On this screen you can choose the type of shading 1: Intersection of the two regions ( the part of the plane that satisfies both inequalities, 2 the union of the two regions or 3 the original shading (as compared to choice 2). Selecting option 1:intersection gives you the following screen.
If you press the [ALPHA][F5] keys you have the HELP ? screen below.
If you press the [ALPHA] [F3] keys you get a Point of Interest (You should consult the manual for the Inequalz application for more details.
By pressing the TRACE button (not ALPHA F4) and the left or right arrows you you can follow the graph of one of the functions. You jump to the other functions by pressing the Up or Down arrows.
To get the manual for Inequalz go to the education.ti.com and download it.
1helpful
2answers
How do I the ALPHA f1 function menu to appear so I can enter fractions
Hi...
You can access F1 by
  1. Press and Release "ALPHA" Key
  2. Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example:
pressing UP and DOWN keys navigates the screen up and down
if we press ALPHA key and then UP/DOWN key, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions.
if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
Dear Sir or Ma'am I have the TI- nspire that has the TI-Plus key pad. I just received the TI-Plus keypad. I install the the keypad and on the screen it shows press Alpha F1-F4 for short cut menu. I see the...
the F1-F4 keys are located at the very top of your keypad. They are also known as the 'Y=' WINDOW, ZOOM, TRACE, and GRAPH keys. If you look at these keys you will see f1-f4 printed on them in green.
Cheers
Sine Wave
4helpful
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
9helpful
3answers
Waiting Please Install Operating System Now.
i finally fixed my calculator~
1. if you have a ti 84 plus silver, plus, or just ti 84, find a friend who has either a ti 84 plus silver, plus, or just ti 84. (as long as the number is the same)
2. link the two calculators together
3. using your friends calculator, press the [2nd] and the one next to alpha [x,t,o,n]
4. go all the way down to [send os]
5. send it to the other calculator and your problem should be fixed
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
