Konica Minolta magicolor 2400 Laser Printer Logo
A
Anonymous Posted on Feb 05, 2014
2400w error light - Konica Minolta magicolor 2400 Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 24, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913044
Points
11959
Which error light what are you trying to do?????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta 2400W Wont try to feed paper.
IT is 16year old today, and there are no spare parts, for it.
cept used on ebay.
the blinking lights in the manual mean, toner cartridge dead or fake one installed. on page 11.
if got it to work there are no windows 10 drivers, now. XP yes.
see that page 11 states on errors.
https://www.manualslib.com/manual/90066/Konica-Minolta-Magicolor-2400w.html?page=11#manual
the service manual is here,
https://www.manualslib.com/manual/805991/Konica-Minolta-Magicolor-2400w.html
RTM?
Hey I have konica minolta magicolour 2400w printer. When i turn it on, it start warming up but after 3 seconds it turns on the ERROR light & the printer doesn't work. Every time i turn it on same issue...
Hi
Usually these machines give you an error code on the control screen. You do not mention one but the webpage here:
Error Codes Konica Minolta Magicolor 2400W
gives most of the error codes for your model.
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Konica minolta magicolor 2400w ready light steady error light blinking possible issues?
The possible reason for error is the printer does notread chip on the cartridges.
The reader for chips locate inside the printer bottom ofcartridges.
Take out all cartridges and you see reader it is a small blackplastic which come three contact plates.
Just clean it with compressed air and take out if some contactplate is sedentary.
Minolta 2400W errors
GO and get 4 Konicminolta image units one for each color and replace them do not use third party. NEVER ever use a vacuum cleaner the static electricity can cause sensors to go bad !!!!!!!!!!!! might have destroyed the chips on the image units SO recommend get all new hopefully you did not destroy the control board with static electricity
The error light stays on
Hi
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner
hope it can fix your issue
Thanks for using Fixya
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
It´s worked by my 2400W feed new toner.
1helpful
3answers
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
