Precor has standardized their error code messages across all their equipment so that each error will have the same meaning regardless of what model or equipment type the message appears
Here we list each error so that you can click through the specific error for additional details about the cause and action to correct the error
Translate this page
Question Product: 2005 Daihatsu Terios 1.3 Question Details: Como reparar el codigode error p1346 en una terios View Answers Search Related.
Translate this page
El c?digo P1346 de toyota refiere al sensor de distribuci?n variable del ?rbol de levas o el circuito sensor de posici?n fuera de rango, esto se condice con el ...
Translate this page
... Codigo Diagnosticos OBD2. Introduzca el Codigo OBDII a Consultar o bien ABS, Check, Motor, Aceite, etc. ... P1346 OBDII Escaner Codigo Diagnosticos OBD2. Informaci?n ... Como reparar los rotores delanteros de un Kia Optima 2001.
I am assuming this is for the radio. If so, there is a general code if you call most Acura dealers they will give you the override code. There is a way to counter lock the code so it doesn't work at all on some vehicles.
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
