I guess this is what you need
View Tascam 2488 PDF User Manual Online
If you have any question about your home appliances you can always check manualbirds.com for free manuals and guides.
SOURCE: tascam 2488
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
SOURCE: Tascam 2488 Recorder
The 2488 has three effects types: “Mic” effects (compression, exciter, de-esser) you use while recording or insert into a channel; multieffects (distortion, amp model, modulation effects, delay, wah, etc.); and an internal send effect (reverb, delay, chorus, pitch shift, flanger, phaser, and gated reverb).
To add effects to an already recorded track you can assign the effect using the internal send loop for the channel and then bounce the track to print a copy of the track with the effect applied.
SOURCE: Tascam 2488 SDRAM error
Jose
I had the same problem. I sent it back to my place of purchase and they sent it to an authorised Tascam repairer. Unfortunately they sent it back twice saying it was fixed when it wasn't. They then decided it needed a ne main board which was going to cost $800 AUS, excluding any labour to install it. In the end I got angry and went straight to the TASCAM distributor and told them my problem and that it was unnaceptable that such an expensive unit needs a new main board in such a short space of time. To my surprise they came back and agreed to replce the main board for fee and the service repair centre did not charge me either. DON'T pay for this. It is obviously some problem with the unit. RING TASCAM in your area or the authorised distributor.
Hope this helps.
SOURCE: TASCAM 2488 won't boot up..HELP!
reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
SOURCE: Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
