As before check the network setting correct ip address cabling usb?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
SOURCE: Printer leaves two white lines when it prints.
I had a similar problem with my 2430DL only with one fairly prominent white line instead of two. I read troubleshooting tips in manual for this problem and first suggestion was to wipe laser lens clean with a soft cloth. I did this and no more white line! If you do not have your manual please email me and I can forward you PDF manual. [email protected]
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
