Service mode code
press
MENU
UTILITY
COUNTER
STOP
0
0
STOP
0
INPUT PASSWORD - 9272927292729272 PRESS END
PRESS SYSTEM 1
PRESS INSTILLATION DATA
PRESS ALL DATA CLEAR THEN OFF ON
To what?????????????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
SOURCE: Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
SOURCE: how can i get a reset code for my konica minolta
hi U can see trouble list [utility +meter counter +stop 00 stop 01 +counter+trouble] U see all error
SOURCE: I have one Konica Minolta
There is no procedure to restore the admin password. It is possible to reset and enter a new password, and for that you will need a technician to make the adjustments on SERVICE MODE (stop,0,C).
