HP DesignJet 330 InkJet Printer Logo
Robert Posted on Jan 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Firmware failure with inbuilt ROM
How do I fix
Pete Fotheringham
Level 2:
Novelist:
  • HP Expert 175 Answers
  • Posted on Jan 31, 2014
Pete Fotheringham
HP Expert
Level 2:
Novelist:
Answers
175
Questions
Helped
85771
Points
280
Unfortunatly the only fix is to replace the firmware chip itself which requires a new main PCA/formatter, I would suggest with the age of this unit that would be most difficult to get hold of and would probably cost more to repair than it would be to procure a 2nd hand more recent unit
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
1helpful
How to fix? Dell mini inspiron 10. Its has a 8 beeps. Failure displays.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
My dvd rom is no longer playing
Always check the connections and power supply first. if this doesn't work and everything is connected, you might try to update the DVD Rom firmware. a program (free) called Imgburn will allow you to check and find any firmware available. If this still doesn't fix it you may need a new drive (they don't last forever).
How to download nokia n73 inbuilt ringtone
Hi
There are two ways to get the inbuilt songs
1. from the following site
and it asks
for password
The Password is : www.gizmogates.com
Just download the file and enjoy!
2. You can get the inbuilt songs from the inbuilt memory itself
for that just download Xplore.sis From
and install on phone
after installing go to menu >tools> configuratioon check all :- "Show hidden files", "
Show system files" ,
" show Rom Drives",
"Show ram Drives".
then click back
now you will see a drive with letter Z (Which is the inbuilt memory )
go to drive z
Now go to
Z:\Data\Sounds\Digital\
There you will see the list of all inbuilt songs
which can be copied by this xplore applicaton to the desired folder.
Hope this will help you.
2answers
I want to find out what a report suspended error 0008 is and how i can get rid of it. Canon photocopier 2018i
ARE YOU SURE THAT IS E008?
hERE ARE THE ERROR CODES FOR 2018
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E196 0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002 Error on writing and readout ROM of image processor PCB (option ROM).
E197 0000 Erroneous communication with printer engine
E261 0000 Zero-cross signal error
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E730 0000 Inside error of the image processor PCB (PDL system error)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Service call 05H,for konika minolta magicolor 2490MF,konika minolta printer
Flash ROM upgrade failure. Engine firmware upgrade failure. Attemp to re-upgrade. Check for proper firmware,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Driver for my cd rom
We do not require Driver for CD drive, it is inbuilt drivers.
If your Cd drive is not working , check these steps to check if it is a h/w failure or not
1) Try booting in safe mode and try playing a cd/dvd
2) try using any other disc
3) try booting from your windows xp/vista disc. you just have to insert the disc and when you see the msg says Press any key to boot from cd . you have to tap a key and if you get a screen says windows is loading file. it is not a h/w failure.
in that case go to device manager and try uninstalling secondary ide controler and restart the system. it works fine then
if this does not work let me know so I can post you another solution but that will lead you to registery editing which is a sensitive part. try this. Hope issue will get resolved by this.
Take care and
Cheers!!!!
Xerox phaser 7750gx
Hiya,
Can you be more specific regarding the Engine Logic Board Failure as in is it timing, rom/ram, micor pitch or NVRAM as code 80 is a failure code for
Engine Firmware Halt Failure .
Ta
Inbuilt mouse does not work
try reinstalling the drivers for it by going to the device manager.Also you can try using it in safe mode and see if that works.Incase is does not work over there than you would have to get it replaced
k24674
Grand Canyon Tech
Grand Canyon Tech
