SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
SOURCE: error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
SOURCE: Can I reset the drum counter for a Konica Minolta
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
