STANDARD DEVIATION CALCULATION SHOWS ERROR: ARGUMENT
SOURCE: standard deviation
Enter the first number, 1.
Hit the σ+ (Sigma+) key. ( n=1 will appear in the window)
Enter the second number, 1.
Hit the σ+ (Sigma+) key. (n=2 will appear in the window)
Enter the last number, 7.
Hit the σ+ (Sigma+) key. (n=7 will appear in the window)
Hit 2nd x2 (by hitting the 2nd key you are actually selecting the x-bar written above the key.) This gives you the mean.
Hit 2nd sqrt(x). This gives you the sample standard deviation which we will use in class.
Make sure you turn your calculator off and on for new data sets.
SOURCE: finding standard deviation on Ti-30XA calculator
You can get instructions from;
http://www.geocities.com/calculatorhelp/ti30xa.htm
It's straight forward to follow.
SOURCE: HOW DO I CALCULATE STANDARD DEVIATION ON MY TI34II
Here is an exemple taken from your calculator s guide book
There is no substitute for reading the user guide.
Hope it helps.
SOURCE: how do i calculate standard deviation on this
Here is a detailed exemple. Hope it helps.
My name is adieh. Hav a great day.
Here are the tips on how to calculate standard deviation using a graphic calculator:
1. Turn on your graphing calculator, go to the stats/editor screen and enter your data set into list1. Once this is done, return to your home page by hitting the home button.
2. Push the catalog button and scroll through the applications until you find "stdDev(". Place the arrow next to it and press enter.
3.Type the word "list1" into the open parenthesis. After you have put that in, close the parenthesis so you calculator doesn't show an error message.
4. Press the enter button. The calculator has done the calculations and you now have the standard deviation of your data set.
Note:
Using 1-var stats in the stats/editor screen will also give you the standard deviation. Using that function will also give you other information associated with your data set.
Hope it helps.
Thank you for using fixya.
