Oops. You posted this in "PC laptops" category! With the front of the split system leaking you need to check the exit drain. Something is blocking it. It could even be that spider webs have blocked it (I've seen that before). Clear that out and the system should stop dripping. Otherwise you'll probably need to call your heat pump/air conditioning service repair team. If you live in Auckland or Waikato in NZ Goldstar Heat Pumps are good http://www.goldstarheatpumps.co.nz/. Otherwise try Google for providers in your city.
