Texas Instruments TI-84 Plus Calculator Logo
b
baccam_n Posted on Jan 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the formula for finding the volume of a cylinder
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Jan 26, 2014
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671176
Points
21595
The formula to find the volume of right prisms and right cylinders is
Volume=(area of base)*height
If the cylinder has a circular base, then the area of the base is PI*R^2
and the volume is Pi*(R^2)*H.
Here R is measure of the Radius, and H is the measure of the Height. R and H must be expressed in the same unit.
1helpful
Volume of a cylinder formula
Volume of a right circular cylinder of radius r and height h is
V=PI*(r^2)*h
Figure out which is the radius and which is the height, then plug in the formula above. Result is in cm^3
What is the Formula for calculating volume of a cylinder
volume is calculated by finding the area multiplied by the length or height . That is Pi X radius squared X length
example --tube 6"dia 12"long what is the volume?
Example 3.1417 X radius 3" Squared =3.1417X9sq " = 28.2740sq" X length 12" =338.688 cubic"
If you want the volume of an engine cylinder , it is the same formula and the length is the stroke of the piston ( distance from TDC to BDC )
How many jelly beans are in a jar thats 23 inches around and 17 inches high?
V = (pi)(r square)(h) V= Volume (the amount we need to calculate)
pi = 3.14...
r = radius of cylinder (remember this is half that of the circumference)
h = height of cylinder
To make it easier for you below are the figures for the Cylinder.
Radius= 11.5 inches
Height = 17 inches.
Now use the formula above to calculate it.
For the Jelly Bean its,
Radius = 0.25 inches
Height = 0.5
Use the same formula above for jelly bean as well.
Once you have both figures, divide Volume of Jar by Volume of Jelly e.g. VolumeofJar/VolumeofJelly
AND VOILA, you have the amount of jelly beans in a jar (Round the figure out)
Cheers!
How to calculate volume
Each specific solid (shape) that has some regularity has a formula which can be used to calculate its volume. If it has no regularity the calculation will be more complicated.
For a right rectangular prism with dimensions L, W, H the volume is L*W*H. For a right circular cylinder with radius r and height H, the volume is Pi*r^2*H.
Once you know the formula, it is an easy matter to use the calculator to evaluate the volume.
Formula of regular solid
There isn't a single formula for solids of different shapes. For a right solid with a rectangular base - volume is base area x height Similarly for cylinder with a circular base - volume = base area x height (base area in this case is Pi x radius2). For a sphere - volume = 4/3 x Pi x radius3
1helpful
730 lineal meters of 200mm pipe how much volume of water
You're finding the volume of a cylinder. This site gives the formula and some examples. You need to do some conversion when you start solving this because some of the dimensions are in meters and others in mm. Just remember that there are 1000 mm in one meter.
Using the formula for a cylinder's volume: v = pi * r * r * h, and the data h = 730 m, r = 100 mm = 0.1 m,
v = 3.14 ^ 0.1 * 0.1 * 700. The result will be in cubic meters, and I'll let you do the math.
The base of a cylinder has a diameter of 6.2 cm. The cylinder is 18 cm tall. What is the volume of the cylinder?
When you have to deal with problems of this sort, you usually are given recipes or mathematical formulas which you apply to find the result. It so happens that for the volumes of cylinders, the formula to use is
Volume = Area of the base times the height=Ab*h
If the cylinder is circular, then the area of the base is that of a disk, Ab=PI*r^2`where r is the radius.
In your case, you are given the diameter (twice the radius) and the height.
Volume =PI*h*(6.2/2)^2, the unit being cm^2
To type in the value of PI, press [2nd] [^] (the latter is key under CLEAR, and above the division sign.
To raise a number to power 2 (to square it), use the key marked x with a superscript 2, or x with a raised 2.
After you have typed in all necessary ingredients in the formula, press the [ENTER] key and the calculator will give you the result.
Now, it is your turn to do some mathematics.
I need to calculate the number of 55 gallon drums that can be placed in a containment pool that measures 8 ft in diameter, and 2 ft. in height. The containment vessel has to hold 110% of the material in...
Calculate the volume of one 55 gallon drum by using this formula
22/7 X Radius squared X hight of cylinder = Volume of large vessel.
22/7 X 48" (Squared) X 24" = Volume in cu in
100.57 cu ft in large pool = 752.315 US gals.
110% of 50 gals = 60.50 gals
752.315 divided by 60.5 = 12.43 drums
Draw to scale the large poola nd then draw to scale the smaller drums and see if 13 drums fit.
Calculation formula
Figure the volume of the entire cylinder, minus the volume of the core. Multiply the weight per cubic inch times the number of cubic inches of poly. To figure the length, you will have an equasion longer than your arm, since each wrap is slightly longer than the previous wrap.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
