Changed the Syncthru password from the default one, and can no longer log in!
To
reset the SWS (SyncThru Web Service) password:
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Unfortunately, there is no way to recover a lost or forgotten password
from a router or access point; you will need to reset the device to
factory defaults. However, once the device is reset to factory defaults,
you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
password.
below.
or forgotten password from a router or access point; you will need to
reset the device to factory defaults. However, once the device is reset
to factory defaults, you can use the default username ("admin") and
If you have changed the default password and have forgotten the
password, you may need to reset the NETGEAR device to factory default
settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost!
Examples include critical things you need to get online, such as ISP
username, ISP password, IP addresses, wireless security keys, and ports
and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used
router, the old information in the router may not be of use to you.
Contact your ISP if you can't connect any computer directly to the
Internet. Then, if there is a connection problem when the router is
added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security
keys, opened ports and services, etc., that you modified. (The default
username is admin and the password is either password or 1234. Try these before resetting the router.)
