Previously the screen froze and would not change. I put it away and it later turned itself off. Now it will not turn on. I pushed the reset button, I tried to adjust the contrast still no results. Recharged the battery, still won't work.
SOURCE: ti-84 plus silver edition
press 2nd and then the down arrow over and over until the contrast is adjusted. Did you read the manual?
SOURCE: Blank screen with new batteries! TI-84 Silver Plus
ON, 2nd, [up] arrow to change the contrast. Works 99% of the time....
SOURCE: My TI-84 Plus Silver Edition stopped working
That actually is a result of water damage. You probably need to replace it, or see about getting it taken apart and dried if the water damage was recent. DO NOT take it apart yourself. Go somewhere and ask if that is possible.
SOURCE: TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
SOURCE: TI-84 Plus Silver Edition FROZEN
The first part of the post is inserted for completeness (and in case you need to readjust the scree. You can just skim through it.
Part A or B will reset the memory. Please read the whole post before attempting the procedures described here.
The first diagnostics you should perform are:
Here are some more procedures to perform
in the order they are presented. Please
read the post till the end.
A
B.
C.
This
step requires the reinstallation of the system. So
to use it you must download the TIConnect 1.6 software from
education.ti.com. You must have the TI USB SilverLink or the TI Black
serial cable ready.You must be connected to the Internet.
If the message "Error! Press any key to
turn unit off. Then turn unit back on."
appears on the graphing calculator, quickly, remove one battery from the
calculator and reinstall it while the transfer is taking place.
You
have several ways to connect the calculator
