Power light blinks red two times then stays amber. sound is fine. DVD plays fine.
SOURCE: my lg 37lc2d tv power light blinks 15 times and
The power supply is a common fault on this model.
Buy a replacement from www.chsinteractive.co.uk
Not cheap though.
Testimonial: "I found the part on partstore.com replaced it and works like new. Thank you"
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
SOURCE: LG 55lh40 tv will not turn on. I REPLACED THE
Only a probe with a voltage trace can figure to the possible SHORT in the circuit board. You need to look for possible signs of heating which can be an indicator to a short . Also check for the secondary +B to the circuit, check the path that leads to the drive and see if there is high potential drop, if so check the drop to get an idea of the short. The list of probabilities can be more and so ONLY a good voltage check can pinpoint the case. Take consensus but do not replace board at high cost with just assumptions.
may be power supply need more information
SOURCE: My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
