SOURCE: TI-15 square root Function
You should enter it as follows [SQRT]36 ) [ENTER/=].
If you define some function f of a variable x you write that f(x), where the parentheses enclose the so-called argument (objet on wich the function acts). It seems that on this calculator the opening parenthesis is implicit: the calculator supplies it when you press [SQRT] but does not display it (a design flaw?). However the closing parenthesis must be entered by you to signifie to the function [SQRT] that you have finished entering the argument. Weird but one can live with it.
Hope it helps.
SOURCE: how do you tak the square root of 64 or the 4 root of any other #
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
5. To extract the squqre root of a number you can use the key on the 3rd line [root x] or the general power key on line 6 with exponent 1/2
Exemple square root of 256
256 [Root x] [EXE] should give you 16
256 [Y to x] (1/2) [EXE] should give you 16 also
Hope that helps.
SOURCE: Square root
It may be that you have somehow changed to a 'mode' that only shows integer values.
Try pressing the green button, then 5, then 9. Then try the calculation again.
If this fails, you can use Google as a calculator - search Google for sqrt(0.4053) and see what happens.. :-)
SOURCE: I have a T1 30xs,
The calculator is able to display fractions and certain irrational number as radicals. However there is the twosided arrow key to
toggle between exact and approximate (decimal).
Here is a screen capture from the manual to give you some more informations.
SOURCE: convert square root to decimal TI-30XA
Press 2nd then F--D key(its means left arrow key or left key from zero)
