Whirlpool Duet Washer 9100 (5 1/2 years old) stopped 3 minutes into wash cycle and is flashing the time remaining. Door will open and buttons work but the washer won't start. I tried holding the pause button down for about 20 seconds. I tried turning the circuit off for about 10 minutes but washer did same thing when I flipped the breaker back on. Help!
Take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
I don't know why this web site posted my question under the Maytag Epic washer section - it's a Whirlpool Duet. How do I move my question?
