MY PROBLEM IS KONICA MINOLTA C452 AS TROUBLE CODE C173
Have a tech come out re-flash th copier os and also check the NVRAM board firmware, mite also be the control board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Error code on Konica Minolta C350
There is not a C0876 listed in the service manual. Perhaps it's a C0B76 - Finishing option Punch Unit Board Malfunction.
CAUSE: The shaft on which the gear rides is deformed. The punch unit cannot be driven from front to rear.
SOLUTION: Reform the shaft toward the punch unit rail. This will allow the drive gears to mesh properly so the punch unit can be mechanically driven from front to rear.
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
SOURCE: need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 -
now you are in service mode, - stop 0 C, and there shold be admin pwd
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
