My 1315 has print had been "crashing" into the right side of the printer case on its rerturn. Now nothing happens-paper won't feed, nothing prints. It's obvious to me that something mechanical has blroken. I shook the whole printer and a small black rectangular part was visible, so I removed it. I'd like to take the printer apart, but I can't figure out what kind of of a screwhead or bolt is used.
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: I have deleted my hp psc 1315 printer, my Compaq
go to hp's website and download the software for your printer it's really easy and doesn't cost anything.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: My hp 1315 check paper is blinking
un clip the back door there might b a jam of paper that u cant see but printer can detect once u have done that u must !! pres enter 2 reset it after u have replaced the rear door of course
