It really depends on the type of building, but in general, open-cell spray foam make more sense economically. Don't kow how relevant it is to you, but it also allows timber to breathe. It's great as a suond barrier because they block twice as much sound as closed-cell spray foam. Oh, and they are also unlikely to harm electric wiring or plumbing parts because of their usually low exothermic temperature.
Hope I helped!
It really depends on the type of building, but in general, open-cell spray foam make more sense economically. Don't know how relevant it is to you, but it also allows timber to breathe. It's great as a sound barrier because they block twice as much sound as closed-cell spray foam. Oh, and they are also unlikely to harm electric wiring or plumbing parts because of their usually low exothermic temperature.
Hope I helped!
If you want to full information about the open cell and close cell click here the given link: https://www.sprayfoaminsulationquotescompare.com/whats-the-difference-open-cell-vs-closed-cell-spray-foam-insulation/
Thank
you for posting your question here on Fixya.com.
Purchase
a can of spray foam insulation and then drill a hole in each end of the handle
to match the spray tube on the insulation. Let the handle dry once the holes
are drilled then fill the handle with the foam from one end until it begins to
expand out of the holes. Once the foam has set you can trim off the excess and
scoop out a dimple of foam from each of the holes. Seal the holes with a
two-part epoxy but even if the handle still leaks the foam will prevent much
water from getting in and the handle will remain buoyant.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated
once your problem is solved!
John
