Machine wont finish washing and doesnt seem to drain. f18 error didi flash up
SOURCE: Bosch Clasixx 6 wash machine
'F18' for Bosch normally indicates a draining problem. As you say the filter is clear, have you been able to check that something is not jamming the drain pump/motor?
So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If both the filter and pump are definitely clear, it COULD be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: The washing machine doesnt finish
This problem is most often the CCU circuit board (inside, top, back, plastic case) there are bad solder joints on the circuit board where the relays (5 of them) and the spade connectors are supposed to be firmly soldered to the board. Often times the vibration of the machine will make or break one of these connections causing the machine to stop at various times. The cure is to remove the CCU case then the circuit board and touch-up those solder joints I mentioned. If your not up on soldering techniques you can remove the CCU case and circuit board and take them, along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
SOURCE: Set machine to wash; Came home to discover machine
Bosch F18 can indicate a drain filter/drain pump problem so I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside. The smell COULD be coming from a jammed drain motor.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
