I am printing from QuickBooks. The checks no longer print on line, they are a few lines below where they should be. Also it takes several attempts before the printer will recognize the paper and actually print the check. It tells me that the wrong kind of paper is in the printer.
SOURCE: HP F380 printer
This happens when your print head gets dirty. Just claening the print head should solve your problem. To do this: Click start button > click Printers and faxes. > Right the printer icon > click properties > Here you should find something like "Head cleaning" or "Clean the print head". This option can be used to clean the priter head automatically. If it does not work, you can manualy take out the cartridge and dip it in to IPA (Isopropyle alcohol) solution would clean the head[dip the head only not the complete cartridge]. After a few minutes (10-20) you can fit the dry cartridge the printer. If nothing works try changing the cartridges. Note: When the ink is running out this may occur. The only thing we can do is to replace the cartridge.
SOURCE: printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
SOURCE: printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
SOURCE: Printing Quickbooks voucher checks with HP 6500 officejet printer
i have nearly the same problem and I'm going to continue to search and write 6500 voucher printing problem
