Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W Logo
A
Anonymous Posted on Jan 08, 2014
Mains lead replacement - Russell Hobbs 15081 Steamglide Iron In White And Blue, 2400 W
David Empson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 8 Answers
  • Posted on Mar 04, 2019
David Empson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
8
Questions
Helped
18201
Points
16
To disassemble the Russell Hobbs 15081steam glide iron, you have to remove the two hidden screws on the handle. To locate the first screw remove the two adjacent blue buttons which are each held in with two hidden clips front and rear, so lever out with small screwdriver or similar. The second hidden screw is under the pivots of the water inlet lid.(I broke one of the plastic pivots but no big deal). Then using a thin blade, separate the top half of the handle from the bottom half of the handle. A bit of force is needed as there are more plastic clips. I started from the rear.
Once the top half the handle is removed, other screws become visible, so teardown is not hard, just note which screws go where, as they are different lengths.
My problem was that some of the screws/bolts were so corroded I needed to drill them out. The thermostat was also corroded, which probably explained why the thermal fuse had blown. The element was fine.
My panasonic NI22AWTXJ iron is not powering
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem.
If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
Why wont it work
Possible that the lead wire, the mains plug, the thermal switch of the heating element is faulty.Unless all these are checked one by one , the fault cannot be confirmed.
1helpful
Iron is not heating. Tried shaking it. It will start to heat then turns off. It is onlt a few monthe old.
If shaking it does anything, you should not use it. It clearly has an internal problem that could lead to shock or a fire. Even if you are not under warranty, most manufacturers will replace a unit with a serious fault that can lead to liability. You should contact the manufacturer directly. They will be very helpful.
Keeps tripping the main electricity on 20A breaker with no lead or bad connection. Advice?
Perhaps you simply have too many power consuming items on that one circuit.
Damaged mains cable
it is betterr to get a sealed power plug with the nylon insulation for the iron with a 15 amps rating wire and plug.
open the unit and disconnect the wire of the damaged plug, remove and replace with the new one taking care to connect each of the wires to the correct position. The lead , neutral and the ground must be double checked before you switch on.
2helpful
Black & Decker Quick/Easy X415 won't stay on
Like most consumer whitegoods nowadays, the cover is 'protected' by 'tamper-proof' or security bits screws that take may forms: you can get the a set of screw driver security bits at most hardware or electronic shops.
The power cord to your iron has one or more electrical lead that has just about broken off due to fatigue failure: it is a dangerous situation because of potential arcing so I would get it fixed it as soon as possible by a 'qualified' person: that said, there are only three wires to your iron and once you get the back cover off, you can easily find out where ths break is by just pulling hard on each wires. The break would normally be fairly close so you have the option of shortening the lead (which must otherwise also be in good condition ) to where the longest break is and rewiring the leads back in exactly the same screw terminals on the iron.
Please remeber that you are dealing with a potentially dangerous main voltage appliance and extreme care is required.
Hope it helps.
1helpful
Iam attempting to fit a new dual cord to my steam generator model 2935 and I have misplaced my drawing of the connections to the iron. Is it possible to get the wiring diagram for the electrical...
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Dec 24, 2009 • Tefal Irons
I plugged the iron on power and it tripped the circuit breaker
check the plug and make sure all connections are secure
check/replace the lead
or finally replace the element
i hope this helps in some way
Dec 23, 2008 • Irons
1helpful
Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Hi, My Tefal Express Steam Iron is not working. The steam will not work and brown water is pouring out the bottom of the iron. I need to know where I should get this repaired in Inner West...
Do you use any additive to the water when you iron?
Do you empty the water out after use ?
Brown steam / water suggests foul water, or rust due to dirty water pipes on Iron.
With regards to 'not working' - do you have any lights on, or is it dead.
(I had one of these, the mains lead within the flex holder had broken - design flaw) - managed to repair.
Top Russell Hobbs Irons Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
