Texas Instruments TI-84 Plus Calculator Logo
A
Anonymous Posted on Jan 08, 2014
Is the graph of a circle a function? - Texas Instruments TI-84 Plus Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Jun 12, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428472
Points
622693
No. The graph of a circle is a graph, one which can have two different values for certain arguments. The graph of the top or bottom half of a circle can be considered a graph of a function.
2 Related Answers
k24674
  • 8093 Answers
  • Posted on Sep 04, 2009
SOURCE: How can I get my calculator to highlight more than
Suppose you want to draw the circle the equation of which is X^2+Y^2=4, a circle centered at the origin with radius 2.
When you isolate Y^2 and then extarct the squre root you obtain two solutions, call them Y1 and Y2
Y1=SQRT(4-X^2), Y2= -SQRT(4-X^2)
You press[Y=] and type in the right hand side of the equations above, one in Y1= and the other in Y2. Press [GRAPH].
Ih a graphic does not appear within the scree window adjust the window parameters ( [WINDOW]) or Press [ZOOM] and select ZoomIn, ZoomOut, ZoomSTD, etc.
Explore the program Draw accessible by pressing [2nd][DRAW].
Hope it helps
k24674
  • 8093 Answers
  • Posted on Sep 13, 2009
SOURCE: Two graphs at the same time
Here is one particulat gase where two graphs are executed simultaneously, yet you see one, but bo the other.84fef70.jpg When graphs are being executed the one for tan(x) is displayed as a bubble that outlines the variation of the tangente. But at the end, it evaporates, leaving only the sine function.
d17b645.jpg Here is the result.
Hope it helps.
Graph a circle
Use the conics utility
Scroll until you find the equation of a circle and an image, Select it, then enter the coefficients.
51b277d6-95dd-4ee0-b9ac-d70af9f67831.png dcd3cce5-60f6-460e-9b7e-d4b3389f6f2d.png ab93170e-7199-417e-aa0d-4247d4482839.png 9881d30b-e071-4404-910f-13d4e8b13b8c.png
Ti 83 only graphs circles
Press "Mode" to go into your settings. Make sure that you are not set to graph "Polar" coordinates. If you are, change the setting back to "Func" or "Function".
1helpful
To graph a circle with radius 4
Press [2nd][PGRM] to open the (DRAW) utility. Scroll down to reach the line 9: Circle( and press ENTER. Complete the command by supplying the coordinates of the circle center and the radius.
Circle(0,0,4) draws a circle with center at the origin (0,0) and radius 4.
By the way the equation of a circle is not a function. You have to cut it into the upper brach and the lower part to graph it.
y=+SQRT(16-x^2) and y=-SQRT(16-x^2)
1helpful
My fx-9750GA PLUS wont graph lines, cicles or paraballas
Sure it does! Did you ask it to graph?Here are some screen captures to help you find your way.
To draw functions (regular, parametric, polar, sequences) use the application graph: Highloghted on 1st screen capture. The second screen captures shows you the functions y=f(x). enter a legal expression and press F6 Draw. To set TYPE press the key under TYPE.
To draw conics (circles, parabolas, hyperbolas, and ellipses) use the CONiCS applications. (See 3rd screen ). On 4th capture the equation highlight is one for the parabola. y=x^2
Scroll down or up examining the small graphs. They will show you which equation form to choose.
For the circles
4helpful
How can I get my calculator to highlight more than one function, to graph a circle for example?
Hope it helps
6helpful
The calculator is only graphing a half circle when it should be a full circle, specifically not in the negative y-values of the plane.
A circle is not a function and cannot be graphed in the regular y=screen. You can graph a circle in parametric mode.
To graph a circle in the regular y= screen, you have to graph it in 2 lines on the y= screen. I assume you've solved for y and gotten a square root equation. Remember a square root can be positive or negative. In line 1 of y= screen graph what you've been graphing and then graph the same equation in line 2 but with a negative in front of the equation. You'll get something that looks like an oval since the calculator screen is rectanglular. To make it look more circular (both parts aren't going to connect), press zoom and then select #5 (square).
Hope it helps.
Graphing circles
You have two methods for drawing a circle on the FX-9750GPlus.
  1. Use the Conics graphing: The general equation of a circle is aX^2 + aY^2 + bX+cY+d=0
  2. Use the function graphing. But before you can do that you must transform the general equation (above) in such a way that you can write it as Y^2= X^2+EX+F. From this you can find the two branches Y1=SQRT(X^2+EX+F) and Y2=-SQRT(X^2+EX+F)
4answers
TI-82 graphing problem
You must press 2nd then "zoom", then go down to axes, and turn them on. Now your graph will work again.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
