I tried to start a load this morning and when i selected my cycle i hit start. Well i got three odd buzz beeps and the drain pump is constantly on. I took the filter out cleaned that and also checked hoses. Dumped water in barrel and it came out..... so not really plugged i guess. it lets me select what i want, locks the door, gives those odd beeps and turns the pump on. Any help would be appreciated. thanks, nate
SOURCE: Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
SOURCE: My GE WCVH6800J front load
Look at this solution (posted by me):
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
Should help you troubleshoot correctly.
SOURCE: you select cycle, the door locks, then unlocks
Check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
