Remove the memory card
from the camera.
Locate the memory card slot on the product that is compatible with your memory card.
Figure 1: Memory card slot locations
1 - CompactFlash (I, II)
2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card
3 - xD-Picture Card
4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo
(with user-supplied adapter), Memory Stick Pro
5 - Front universal serial bus (USB) port (PictBridge-enabled)
NOTE:
Some
portable USB flash drives with a read-only partition, such as U3 smart
drives, might be incompatible with the front mass storage port on your
product. These partitions are added by the manufacturer and may include
utilities and other software. Refer to the manufacturer for additional
details about your drive.
If it is not already on, turn the product on by pressing the power bHP C5180 All-in-one : Memory Card Error, No memory - c01324469.gifrc="/uploads/images/c01324469.gif" alt="c01324469.gif" class="h_mi" />
Turn the memory card so that the label faces inward and the contacts face the product.
FHP C5180 All-in-one : Memory Card Error, No memory - c01335108.gifrting the memory card
CAUTION:
Inserting the memory card in any other way might damage the card
and the product.
Gently
push the memory card into the memory card slot until it stops. The
memory card does not insert all the way into the product; do not try to
force it.
When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green.
CAUTION:
Never attempt to remove a memory card while it is being accessed. Doing
so can damage files on the card. You can safely remove a card only when
the status light next to the memory card slots is not blinking. Do not
pull out a memory card while the light is flashing green.
Step two: Print the photo
Press
Photo Menu
. A message displays on the control panel with the number of files found on the memory cHP C5180 All-in-one : Memory Card Error, No memory - c01185072.jpg
HP C5180 All-in-one : Memory Card Error, No memory - c01185108.jpgli>
Press the right (
) and left (
) arrow buttons to browse through the photos on the memory card.
When the photo number you want to print appears, press
OK
HP C5180 All-in-one : Memory Card Error, No memory - c01185072.jpg selecting the photos, press
Photo Menu
again.
Press the right arrow button (
) to select Number of Copies
, and then press
OK
HP C5180 All-in-one : Memory Card Error, No memory - c01185072.jpgess the right arrow button (
) to select Layout
, and then press
OK
HP C5180 All-in-one : Memory Card Error, No memory - c01185072.jpgli>
) to select Paper Size
, and then press
OK
) to select Paper Type
, and then press
OK
Make any other appropriate changes to the settings, and then press
Print Photos
okie i got it figured out...
Maybe the cache for memory card is stuck.
i used a paper clip to try pushing at all the 4 slots.. and its ok now!
