HP Deskjet D2360 InkJet Printer Logo
Posted on May 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper will not feed into machine
THE d1360 LIGHT KEEPS BLINKING AND WILL NOT PRINT.
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on May 21, 2009
Anonymous
Expert
Level 2:
Answers
192
Questions
Helped
57904
Points
312
Is the paper in the right tray which should be at the bottom and make shure tha paer is completly pused all the way is tell it hits the rolers.
  • Anonymous May 21, 2009
Blinking Light with no cartridge problems My HP Deskjet D1460 has its light blinking with no status messages that suggests an error. However, I am unable to print as the light keeps blinking. Could...
Hi
this problem has many reasons :
- no paper or error in paper feed sensor.
- jammed paper in printer thats prevent it continue.
- try to disconnect usb cable and if its stop lighting reinstall the driver
- else you must search about hardware errors
7helpful
Paper red light blinking. paper is full. What could be wrong? Will not print
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
1helpful
2answers
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
4helpful
Red "Paper" light stays on; printer will not print.
1helpful
My HP Deskjet D1360 printer green light keep blinking.can't take printout.The machine does't get the paper inside. so send the solution
you have a paper jam
pull out the paper tray, check for the jam if all is well, open the printer, check under the printer cartridge, then the back
a little piece of paper will cause the jam
it is a good idea to use canned air to clean your printer, under the cartridge and the rollers on a regular basis (once a month)
1helpful
Paper Light Blinking
make sure the rear part of your paper tray is not pressed too tightly against rear of paper. it will prevent the paper from raising up fully to the feed roller. you can also try cleaning the feed roller if that doesn't do it.
hth,
razors
Printer will not print from tray 1 only MP tray, data light keeps blinking
Have you gone into the printer properties and changed the feed tray? If not to do this go to file and then print ( if hit the print button on the toolbar it will just print), beside the printer model there is a properties button, in there near the bottom you can change which tray you want the paper to feed from. Hope this helps.
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A [email protected]
2answers
EPSON SYLUS C80 indicates "printer error: paper jam"
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
k24674
Grand Canyon Tech
Grand Canyon Tech
