I can not hear anything with the Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card with remote desktop. I have tried everything. Is it possible? I have tried bring the sound to this desktop and everything, but nothing seems to work.
نطلب منكم السماح رفع deriver saa7130hl
I had the same problem with this plugged into my onboard realtec HD 7.1 sound card. I ended up fixing this by enabling all the audio settings (line in,s/pdif in, and even individual speakers). After doing that I had all sorts of volume controls. After tinkering around I discovered that for some reason the volume on the front left and front right was all the way down(not muted), and after turning them up I had sound. I don't know why that mattered but it did. Hope this helps.
P.S. For some reason with that onboard sound card I could watch live t.v. and hear it, but when I record it would have video but no audio. After looking at the advanced volume controls in my onboard sound I noticed that all the individual volume settings(line in,mic,etc.) were greyed out and not accesible, but the main volume was accesible. I fixed this by plugging in my old sound card and everything was fine. And yeas everything was plugged in right. Hope this helps
HELLO
Hi.
I want philips saa7130 hybrid capture device in windows 7
thanks
Hi All
Jjjjjjjjjjjjjjag
Hi! My name is Ruslan. I need driver for Philips SAA7130 TV Tuner. Please help me find a driver!
My mail is [email protected] or [email protected]
Drivers download site:
http://www.kworldcomputer.com/download/download_pvr-tv7131.htm
Drivers software and manul for phillips tv and radio tuner card 7130
http://www.divshare.com/download/4120814-887
J'ai trouvé le lien avec le SAA 7134 merci cher internaute pour ta grande contribution à resoudre mon problème que dieu lui même te donne plus de bénédictions AMEN
vinc de paul BROU à ABIDJAN côte d'ivoire!
This device is not configured correctly. (Code 1)
Vida bela
vida bela
SAA 7134: I have solution in Windows 8.1 64 bits, but, i no speak english. My e-mail: [email protected].
SOURCE: Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems
Have you checked the installation? - most PCI capture cards use the audio card of the PC for sound. A jumper cord is needed to come out the capture card and into the audio line-in jack. Green jack on the capture card is OUT, and the Blue jack on the sound card is Line IN.
Please describe the specifics of your problem below. We'll add
your post as a comment to bjlove86's Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems problem, and notify you when a new solution is offered
i have same problem, first I buy a TV tuner is ok, but after I uninstall TV tuner and install again I can't hear a sound but if hear another music i can hear sound, can anyone help me
I too.
i want to donwload Philips TV tuners SAA7131E driver download .. plz tel how get this driver and download.... thanks
philips SAA713 tv card driver
I HAVE THE SAME PROBLEM ,MY TV TUNER CARD DOSEN'T HEAR AUDIO , PLS HELP ME
I have Philips SAA7131E, and the (S-Video) picture is only black&white. Also, I can not turno on FM radio at all. Where could I get the right driver?
i am using philips saa7130 tv tuner pci card i can't hear any sound & when use record it is recordind but i cant hear any sound please help me to solve this prob
My audio doesn't go up and down with the volume control. My input on the computer is not working so I have to listen with headphones plugged into the output, but I'd like to have the volume control work. Is there an updated driver?
SAA7130
I just brought a tv card saa7130 but its aint work it said it cant find the driver for it . Tell kme wat to do now
hi,
i have the same card,but i cant seem to tune it or get any signals from it. the cd that came with it got broken and i downloaded the drivers and live view tvr interface to run it. please can i get instuctions on how to tune it or what to do to make it work. i live in nigeria west-africa.
What I did is to connect the sound to external receiver and it work I can hear now, so if you want to work connect to external speaker not to in line from the cpu sound card.
when i capture a clip there is only video no audio.why.i can here sound while the TV goes on.please help.
i want to donwload Philips TV tuners SAA7131E driver download .. please tel how get this driver and download.... thanks
I have the same problem , NO SOUND it will play sound during the recording but no play-back, but I also noticed that the sound option on the software is greyed out which I assume means the software supplied is not right or the card is junk, seeing all the same problems I would say the drivers are not correct for this card anyone know where to get updated drivers for this?
dose not work with windows xp
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card saa7135hl
very good
i can see cable but i just going to record video the video can recording successfully but the video can not playing sound
no tengo imagen
During hardware installation, no driver is found by system, even from the CD with the CARD. Finally a message appear: A problem encountered during installation, your hardware may be work properly. and This doesn't work at all.
Hey, SPDR is there can someone tell me how to capture qulaity movie but less in size when i record it consume almost 20 MB of my HDD space for just 10s movie clip. pls help me [email protected]
have you tried plugging it back in ?
sometimes these cards just need to be unplugged , computer restart , shut down , plug it in and walla! it works again! as long as you have the drivers (which sometimes have to be reinstalled) this procedure could help your card, if absolutely your card will not work its broke and unrepairable.
send all your broken electronics to me!
electech
