Machine stops mid-way through rinse cycle with water in the drum displaying error code '3', any ideas?
SOURCE: Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
SOURCE: 2nd Bosch washing machine same problem
put tester on drain pump power wires and see if power is there. if so,your pump or the line is blocked.
SOURCE: Drum not turning (WFL 2260)
possibly the belt is off/broken? can you hear the motor turning when the drum is supposed to be revolving? If not supect the motor carbon brushes, or some other fault with the motor/and /or circiut, at best it may be a burned out wire to the motor
SOURCE: error code E02 on washing machine-3 beeps
you should buy a new one..
check this one..
http://www.washingmachineadvisor.com/
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
