Maytag top load washer
IE ERROR, INLET VALVE ERROR
OE ERROR, DRAIN ERROR
FE ERROR, OVER FLOW ERROR
PE ERROR, PRESSURE SENSOR ERROR
dE ERROR, DOOR OPEN ERROR
tE ERROR, HEATING ERROR
LE ERROR, LOCKED MOTOR ERROR
bE ball sensor error code
EE defective EEPROM
bs2--vibration sensor check
INLET VALVE ERROR
DRAIN ERROR
CL Flashing, Child Lock
PF Error, Power Failure
CE Error: Communication Error
UE Error: Imbalance Error
SOURCE: Getting error code on lg front loader washer
Hello aj546,
Kinda figured there was a miscue there with your error code however... the error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)... If you still get the FE test..call for service.. That's the best I can offer via this chanel... BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open... Hope that helped you..'
Regards,
Rick
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
SOURCE: LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
SOURCE: maytag bravos top load washer error code F1
Well, you're not gonna like this, but here's the deal.
Remove the three screws on the rear of the control panel and lift it up. Disconnect the rubber hose on the right side of the gray control module and blow through it to make sure it is clear and not kinked. If this check is fine then your control module needs replaced.
Note that Maytag knows this is a fairly common problem. My washer failed 9 months out of warranty with this problem.
The only good news is that it is an easy, though expensive, replacement.
If you place a couple magnets over the left gray bumper and the "OP" error code doesn't clear then I feel you have a problem with the Left Hand Lid Lock.
See if this post will help; Left Hand Lid Lock Troubleshooting
