Question about Konica Minolta Bizhub C452 Copier
C163 on b52izhub c5
I have some problem on bizhub c552 code c.c163 and one machine has c.3b02
  • Konica Minolta Master
  • 1,316 Answers
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Posted on Dec 29, 2013
SOURCE:
Machine has error code c-3b02
Check the fuser unit the HOT Part. ensure properly installed. could be the fuser control board or the fuser High Current coil that part the fuser sits up against.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 18, 2016 | Konica Minolta Bizhub C652 Color Copier...
Error c-c163 konica minolta bizhub c451
You have the wrong firmware in the machine. What ever is in there needs to be replaced with the proper firmware.
Oct 11, 2015 | Konica Minolta Office Equipment & Supplies
ERROR CODE C3B02 KONICA MINOLTA C552
Have you changed the fusing unit? If try that first, then relace the IH Power supply or the (coil unit) is what the fuser attaches to when you install one. power supply is located right side under the control panel, .
Sep 23, 2015 | Konica Minolta Bizhub C552 Copier
Konica Minolta C552 error code C-B02
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Jul 17, 2015 | Konica Minolta Bizhub C552 Copier
C-3B02 in bizhub c452
This going to get expensive, could be any of the following the IH coil unit or IH Power supply unit. This series of machine uses a magnetic field to produce heat for the fusing process the process of fusing the toner to the paper, any way the code you have is stating the IH pwr sup or coil unit are not talking to the copier cpu. It could also be a relay board between the cpu fuser system, worse case the image control board. I would go with fuser power supply. Just my humble opinion.
Jan 30, 2015 | Konica Minolta Bizhub C452 Copier
BIZHUB C552
again please explain?
Jul 07, 2014 | Konica Minolta Bizhub C552 Copier
What is bizhub C552 p-14 error?
p codes are warnings that a consumable is reaching the end of its life you can go into service mode and it will give you a list of error codes including p codes
Jul 04, 2014 | Konica Minolta bizhub C552 Waste Toner Box...
Minolta bizhub C552 code c3102
replace the fusing unit
Apr 26, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Konica Bizhub C452 Error C-3B02
chek your register conector
open the front door and clean conector
May 26, 2012 | Konica Minolta Bizhub C452 Copier
What does Error Code C2564 Konica Minolta Bizhub 552 mean
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Apr 24, 2012 | Konica Minolta Bizhub C552 Copier
Konica Minolta Bizhub C452 Copier Logo
314 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
