At present, I have set tv to hdmi 1 plugged aerial from satellite dish into freesat box connected scart cable from freesat box to dvd connected scart cable from dvd to tv connected hdmi cable from dvd to freesat box
SOURCE: Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
SOURCE: Changed HDMI settings and can't now see image on screen
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
SOURCE: I can't set up DVD player correctly to record t.v. shows
ok let's start from simple connection.we'll use color coding,let's say rca plug. yellow plug is video.from DVD video out is yellow and to the tv is video in. white and red is for audio.if your tv is 5.1 compatible then follow the label on your DVD and insert it to its corresponding label on your tv.then still if your using a separate audio amplifier only the yellow/video plug is used.
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
SOURCE: Cannot record from my DirectTV DVR, HR20-700
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
