Texas Instruments TI-84 Plus Calculator Logo
A
Anonymous Posted on Dec 21, 2013
SciTools for TI-84 color - Texas Instruments TI-84 Plus Calculator
1 Related Answer
k24674
  • 8093 Answers
  • Posted on Feb 14, 2010
SOURCE: Change TI 84 OS to TI 89 OS??
And why, pray tell, would you do such a thing? You will ruin your Ti84 Plus Silver Edition and will not have a working TI89. Besides, TI connect will refuse to transfer it.
If you like the capabilities of the TI89 Titanium, buy a cheap or used one on e-bay or amazon.com and spare your TI84PLus SE.
How do i install the ti-84 operating system to the ti nspire
You do not. The TINspire with TI-84 keyboard works as a TI-84 Silver edition. Its OS is update when the TINspire OS is updated. The Ti 84 OS's you find on the TI website are not for the TINspire with TI84 keyboard.
2answers
There's a blank bar that runs horizontal in the middle of my TI-84 plus that's about 16 pixels wide(high?). It's the same color as when the device is turned off. I've tried a memory reset and no results....
SPLIT SCREEN.
It sounds as if you might have split screen mode on. I've got a TI-83 as well as a TI-89 Titanium, both offer a split screen mode. The latter allows for choosing which applications are displayed on each half screen. I am presuming that you may have accidentally put your TI-84 in this mode.
So, if it is a split screen deal then all you have to do is go to the mode screen, find the option for switching from split screen to full screen, and switch it back to full.
I hope that helps. Give us your results!
Adios
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
1helpful
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
How do you find the table which has the prefxes [giga mega ... ] ?
  1. Press the [APPS] button.
  2. Scroll Up to reach the bottom of the list.
  3. Select SciTools and press [ENTER].
  4. The splash screen can be dismissed by pressing any key.
  5. Select [2:Unit-Conversion], then
  6. [ALPHA][C: SI prefixes].
The screen that is displayed has them all. Use the navigation arrows to highlight the one you want
1helpful
How do you do conversion on this calculator?
If you have the SciTools app loaded:
Press APPS, then select the SciTools app. Press any key to continue. Press 2 to select the Unit Converter. Press digit/letter to select the type of unit to convert.
Enter the number. Navigate to the unit. Press ENTER. Navigate to the unit to be converted to. Press ENTER to see the result.
If you don't have the SciTools app, you can download it from the manufacturer's web site at http://education.ti.com/educationportal/downloadcenter/SoftwareDetail.do?website=US&tabId=1&appId=205
You can also download the guidebook for the app from the same page.
2helpful
How do I convert with the TI-84 plus
You can do unit conversions with the SciTools app. If it's not already installed, you can download it and the guidebook from the manufacturer's web site at http://education.ti.com
Start the app, press any key, then press 2 to enter the unit converter. Press a digit or letter to select the dimension. Enter a number, navigate to the unit and press ENTER, then navigate to the unit to convert to and press ENTER again.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
