Its looking for the fax board ??? Some one remove it????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
SOURCE: how do i set up a scan box on my konica
Konica has a free program called PageScope Box Operator. You can download it from Konica's Web Site or it comes on the disk you should have gotten when you got the machine. Install it and from there you can pull up your scanned documents and you can create boxes. Plus it keeps everyone from accessing the printers Web Utility.
SOURCE: change the transfer unit on a konica Minolta
open right door, remove 2 lock screws and pull out the tbu
