P
Parker Leib Posted on Dec 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ti 84 plus wont graph
When i try to graph it says ERR:UNDEFINED
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on Dec 19, 2013
k24674
Level 3:
Answers
8093
Questions
0
Helped
4671816
Points
21595
You might have used an inappropriate variable name.
For functional graphs y=F(x), the independent variable must be X
For parametric graphs, the independent variable in the x_t and y_t functions must be t.
For polar graphs the independent variable must be Theta, and for sequence graphs, it must be the special wiggly n.
Once you select the type of graph, the independent variable is entered by pressing the key marked X,T, Theta, n.
5 Related Answers
Anonymous
  • Posted on Jan 04, 2008
SOURCE: graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Anonymous
  • 4 Answers
  • Posted on Feb 03, 2009
SOURCE: TI-83 Plus Graphing Error
Try zoom 6
Anonymous
  • 69 Answers
  • Posted on May 14, 2009
SOURCE: when i try to graph a scatter plot on my ti-83
Your stat plots are on, and may not be filled out/ correctly filled out.
go to [Y=] and go up to the stat plots ([Plot 1], [Plot 2], [Plot 3] ) and turn off the ones that are "ON" ( highlighed black w/ white text.) and press [ENTER] on the ones that are on and the problem is no more.
Anonymous
  • 88 Answers
  • Posted on Aug 15, 2009
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
k24674
  • 8093 Answers
  • Posted on Oct 25, 2009
SOURCE: TI-84 Plus LCD display broken. Is replacement available?
Contact [email protected] or www.ti.com/calc .
Hope it helps
3helpful
Error: Invalid
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
1helpful
Im trying to graph inequalities on my ti 84 plus, and it keeps saying ERR:INVALID DIM. how do i fix it?
Try deactivating the Statistica plots.
Press [2nd][Y=] to enter Stat Plots. Press the PlotsOff menu option.
1helpful
When I try and graph on my TI-84, "ERR: INVALID
1helpful
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
18helpful
Whenever I try to graph something on my TI-84 plus I get the message err: invalid dim
When i click graph it says "ERR: INVALID DIM" i noticed under "y equal" mode that plot 1 and plot 2 are highlighted. how do i fix this, i need to be able to graph. TI-84 plus calc.
On my TI-83 Plus calculator, everytime I try to plot a graph, or lets say just press TRACE or GRAPH I get ERR:UNDEFINED, what can I do to be able to see the graphs that should appear after I put the...
First lets make sure you have a manual. go to: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010670.pdf Go to chapter 3 and it explains the details in graphing
4helpful
Not Graphing
If that's not it, post a comment and we'll go from there.
Suddenly, the graph window reports ERR:UNDEFINED
Go to Window and make sure there are acceptable values for your graph, default is usually 10 and -10 with 1 scale.
k24674
ADMIN Andrew
ADMIN Andrew
