Computers & Internet Logo
Posted on May 14, 2009
ScanSnap Manager - Error!! You do not have a write authority for the installation folder.\nMake the selected folder writable.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 08, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12407
Points
Normally this error will only come up when you have already tried installing the Scansnap Manager.
Go to C:\Windows\SSDriver. Right click the folder and select properties, select the security tab, then make sure "Users" has full control.
Repeat these steps on the PFU folder in Program Files.
Put in the Scansnap disk and navigate to the Tools folder. Run the SSCleaner tool and delete all of the Scansnap components.
If Scansnap Manager is not listed in the Cleaner tool, Delete the contents of the SSDriver and PFU folders manually.
Restart the computer and reinstall the components.
3 Related Answers
Anonymous
  • Posted on Jan 12, 2009
SOURCE: error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Anonymous
  • Posted on Oct 23, 2008
SOURCE: Won't install ScanSnap Manager
The CD is defective. Get another CD and try it. I was having the same problem. I browsed the CD because I wanted to install just the Scan Snap manger. I discovered that the CD ROM could not read that part of the disk, so I tried the installation from another CD disk, and it worked like a charm.
Anonymous
  • 5 Answers
  • Posted on Sep 19, 2008
SOURCE: "Failed to initialize the sRGB engine" - ScanSnap won't work at all :(
not download just tell me serial number.
I have a scansnap ix500. I am getting internal error 202003 when scanning receipts. It says the receipts are unregistered. I deleted scansnap receipt and reinstalled but I still get this error.
Please try the following steps to establish the connection:
1. Restart your ScanSnap. Turn off your ScanSnap, wait at least 5 seconds and then turn it on again.
If the icon status is not changed, unplug the USB cable from the computer or your ScanSnap,
wait for 5 seconds, and then reconnect the USB cable.
2. Connect the USB cable directly. If your ScanSnap is connected via a USB hub, try connecting your ScanSnap directly to the computer via the USB cable.
3. Turn-off antivirus software. Turn-off antivirus software and try again.
4. Use another USB port. Try with another USB port if any.
5. Use another USB cable. Try with another USB cable if any.
6. Disconnect other USB devices. Disconnect any other USB devices (printer/scanner/external hard disk and the like) and try
again.
7. Use ScanSnap Support Tool. Connect your ScanSnap to a computer and follow the steps below with ScanSnap support tool.
* To run ScanSnap Support tool, go to the [Start] menu --> [All Programs] -->
[ScanSnap Manager] --> [ScanSnap Support Tool].
  1. Click the [Check] button under [Check Privileges]. If the message, "The recommended privileges have been applied." appears, turn off your ScanSnap, wait for 5 seconds, and then turn it on again.
  2. Press the [Recover] button of [Recover ScanSnap Connection] to see whether it solves the problem.
8. Full shutdown Windows®. (Windows® 10 only) Click on [Shut down] while hold the Shift key on keyboard and shutdown Windows®.
9. Delete the device driver. Delete the device driver to see whether it solves the problem.
Follow the steps below to delete the device driver:
    1. Connect your ScanSnap to the computer, and turn on your ScanSnap.
    2. Open the Device Manager window. For Windows® 10 Right-click the [Start] menu, and select [Device Manager]. For Windows® 8.1 Select the Down Arrow icon on the lower left side of the Start screen -->
      [Control Panel] under [Windows System] --> [Hardware and Sound] -->
      [Device Manager]. For Windows® 7 Select [Start] menu --> [Control Panel] --> [Hardware and Sound] -->
      [Device Manager].
    3. In Device Manager right-click [Imaging device] --> [ScanSnap iX500] or
      [Imaging device] --> [Other devices] --> [ScanSnap iX500] --> [Uninstall].
    If the ScanSnap used to be connected other USB ports, connect it to each of those ports and repeat these steps.
  1. Turn off your ScanSnap.
  2. Disconnect the USB cable from the computer.
  3. Restart the computer.
  4. Reconnect the USB cable to the computer.
10. Reinstall ScanSnap Manager. Uninstall and install ScanSnap Manager again.
If the issue persists after attempting all the procedures above, please collect system information on the computer and send the data to a FUJITSU scanner dealer or an authorized FUJITSU scanner service provider by e-mail. To collect system information, press the [Collect] button of [Collect System Information] in the support tool, and it creates a folder (ScanSnap_date and time) that contains the system information data. We would appreciate it if you could send the data in zip format.
* Refer to [Troubleshooting] in the [Help] menu of ScanSnap Manager.
5helpful
When I try to scan, I get "Undefined error occurred (0x80004005). A probable cause is that the system is unstable. Reboot the system. If this does not resolve the problem, contact the store where you...
I just fixed it. Uninstall the application by choosing applications and finding scansnap. Drag the folder to the trash. power down your scanner and unplug the USB. Go to the Fujitsu website and download the software again and reinstall it. Plug in the power and USB into your scanner and everything should work fine.
Hello, I'm getting an error message on my ScanSnap for Mac. It's saying "undefined error 0xffffdcf7. Never had any problems till today. Please help !!
I also had this issue. I was running an older version of Scansnap Manager.
I installed the latest update Version 2.2 (January 2011) and it works fine now.
Here is the link to the Upgrades.
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Hope this helps
1helpful
Scanner will not pull the paper all the way through & scan. Scanner says not valid folder to save image is selected . Set the save folder for the scanned image data. I don't know what to do
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select “Scan Button Settings” from the Right-Click Menu.
2344c41.jpg Select the “Use Quick Menu” check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the “scan” button on the ScanSnap.
Click the “Scan to folder” icon in the quick menu when scanning is completed.
The “Scan to Folder” dialog box appears.
Check the scanned image in the “Scan to Folder” dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
1helpful
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
20helpful
2answers
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
5helpful
2answers
Error while attempting to install ScanSnap Manager on Win XP Pro
3answers
Driver scansnap
There should not be any problem installing that sofware on that OS and version. My guess is you have a botched (corrupted) install. Try uninstalling if you can otherwise let me know and we'll "clean out the registry." Good luck!
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
